Wireless usb connection
I am struggling to connect my zyxel usb adaptor so i can go online in another room
it says it is searching for new ip address and then it stops.
    Problem Solver:
  • 8 Answers
Unable to connect for setup
It could be that some other wireless device has the same IP address as the Zyxel AP. If you have not changed the Zyxel's default IP address 192.168.1.2 , I would recommend it. Try something like 192.168.1.100
Hers the link to the manual:
ftp://ftp2.zyxel.com/WAP3205_v2/user_guide/WAP3205%20v2_1.0.pdf
Mar 13, 2014 | Zyxel WAP3205v2 Wireless N300 Access Point
I have a ZyXEL EQ-660R-F1 and a Linksys Wireless Router (B BEFW1154) that I'm trying to hook up. Can you tell me what I need to do?
Who is your ISP (internet service provider)? Anyway, it is possible to get your set up working. ZyXel is the DSL modem gateway and Linksys, your router/wifi. If you are able to get online by hooking up directly to the Zyxel, then it is possible to add the Linksys to the system.
Dont hook up the Zyxel to the Internet port of Linksys just yet. First you have to configure the Linksys by connecting your PC to it with a cable. Boot up the PC.
Open web browser and enter the address 192.168.1.1 and hit enter. This is the default address of the Linksys. username = admin and no password. It is probably the same as the Zyxel which causes the conflict.
The first set up page may look something like this below.
Change the LAN IP address from 192.168.1.1 to 192.168.2.1
Then click apply...From now on the Linksys IP address is 192.168.2.1.
Now you can connect the Linksys internet port to the Zyxel. Reboot the Linksys and Zyxel.
Your PC should be on the internet after that. To check/setup wifi, you need to log back into the Linksys using the new adress x.x.2.1
Feb 15, 2013 | Zyxel Prestige 660R Router (91004397002)
Got a netgear usb wireless adaptor, it won't assign an IP address for this computer. Where do I set the DHCP to assign an address automatically?
Open Control Panel - Network Connections then right click on the Wireless Network (USB wireless adapter) and then click on Properties. Then in "This connection uses the following items" scroll down to Internet Protocol (TCP/IP) then click on Properties and in the General tab select "Obtain an IP address automatically" also select "Obtain an DNS address automatically" Then click OK
Apr 07, 2011 | Computers & Internet
Hi,i just bought new laptop and my laptop want to connect to wireless. So the wireless modem is inside my housemate room and my housemate now currently stay at out country. So have anyway can i get the...
if you mean the WEP key to be able to connect to the router then there is no way of getting this Legally but if you are connected to the router already and you just want to access the control panel then enter the routers ip into your browser address bar. the default ip for this router is 192.168.1.1 the default username is 'admin' and the default password is '1234' if it has not been changed by your housemate.
Nov 25, 2009 | Zyxel Prestige 320W Wireless Firewall...
My wireless network is detected by my computer, but I cannot connect, what should i do?
If your network is WEP or WAP encrypted try to reconnect your computer and provide the key. Else go to your PC and Remove all wireless netork configurations you made so far to connect to the network. Restart your computer and search for the network. Don't configure the PC for the new network just search for a wireless network and when you find it connect it.
N.B. Check your wireless adapter's IP. If your network uses automatic IP addressing check to see if your computer's IP is set to automatic no static
Nov 22, 2009 | Zyxel P660HW-D1 Router
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Zyxel nbg334w router configuration
Hi
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Configuring nbg334w router
ipconfig /release
ipconfig/ renew
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping yahoo.com and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
