Music Logo
Posted on Mar 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I get a discontinued item?
A few years back I bought an AKG wireless system consisting of
a UHF SR 40 diversity receiver and a matching guitarbug transmitter
both operating on the "purple" US58 carrier frequency of 734.6 MHz.
At the time I bought it, a snapon SO 40 transmitter was being
offered as an add on to an existing microphone to make it wireless.
I didn't have a need for that at the time, but recently I have found
a perfect use for the SO 40 in my current setup.
Needless to say, I was very disappointed to discover that
this item has been discontinued!!!
Is it possible that you have one of these lying around on a back
room shelf someplace??? Do you know where I can get one???
I would really like to use it with my existing receiver.
I would be willing to buy one "as is" with no implied warranty
as I know your product has been discontinued.
Can you help me out with this or perhaps point me in some other direction.
Thank you,
Jeff Thorn
Tucson, AZ
Level 3:
  • Music Master 19,187 Answers
  • Posted on Mar 06, 2017
Music Master
Level 3:
Answers
19187
Questions
0
Helped
4345730
Points
82261
3 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Jul 28, 2010
SOURCE: Problem in RF Power Amplifier
Look in the "Radio Amateur's Handbook" and past issues of the QST magazine. There have been articles on design including schematics and circuit layout in past issues as well as the Handbook.
Here is a site for a kit for a 10 watt amp... it is for 2MHz to 30MHz, but you can add turns to the transformers to get performance at 1MHz.
http://www.kitsandparts.com/linearamp.php
There is adequate info for design at the site and parts callout and layout.
Fred Yearian
  • 5603 Answers
  • Posted on Aug 20, 2011
SOURCE: Would I need a mixer or amplifier with this
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Ben Goris
  • 37 Answers
  • Posted on Nov 03, 2012
SOURCE: Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.
- thegorisb
Backup sr16 to another sr16
You can send the current patches and programs along with your songs and sequences via MIDI cable from one to the other. Done it many times using a MIDI thing called SYSEX dumps.
You have to hook the MIDI OUT of the unit you want to duplicate to the MIDI IN of the new machine.
Go through the SYSTEM menu and there is a menu item for SYSEX DUMP. Select that and hit the enter and the new one will receive the dump. Both of them will be programmed identically.
My Samson Airline AG1 transmitter will turn on for one second, red light and all, and then turn right off. If I move the battery back and forth, red light goes on then off as well. What's up?
You are aware that the indication LED is supposed to work that way correct? If you do not know, the circuit is supposed to make the LED blink once when the unit is turned on. The speed at which the LED returns to the OFF state tells you approximately how much life is left in the battery. Ultimately when the battery is drained too much for normal operation, the LED will stay lit until the battery is nearly dead. That only explains the correct operation of the LED which sounds like what you are describing. So the only way you can know for sure if the transmitter is working is with a matching receiver that you know works. Unfortunately if there is no indication at all at the receiver, its difficult to tell whether the transmitter or receiver is at fault.
1helpful
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
Need replacement bug reciever is sr40s 751.550Mhz can i get from you
I have UHF SR 40 i look for transmitter GB 40 or if i don't find, i can selt it...
Where can I get lowest price on one of these
FixYa Subscribers have access to unlimited tech support, articles, and Experts!
The audio drops out. intermittently. seems to be related to the movement of the speakers head, but not conclusive. i tested the mike by plugging into a computer. it did drop out a couple times, but again ....
Wireless audio devices are subject to interference. You are a SECONDARY user of the frequency band and hence must put up with being interfered with AND should you cause interference to a licensed service, you must cease using the system. You should try other channels on the unit to see if you can find a clear channel that will not drop out. At UHF frequencies, reflections and change of positions and surroundings can cause dropouts of a system like this. Plugging into a computer is SURE to cause problems as they emit nterference at a multitude of frequencies in operation. Best to NOT have a computer operating in the area of the receiver for this system. In the back of the manual of all of these devices and computers is a note for FCC complaince regarding interference... few read it... but you should as it is the official, legal, position about RF interference between services.
I OWN A PAIR OF GB40 GUITAR BUGS BOTH BROKE FROM BEING OVER FLEXED ON MY STRAT. MY QUESTION IS CAN THEY BE FIXED AND ARE THERE PARTS AVAILABLE.
To determine if either or both can be restored to a useable state, you would need to send them to me for evaluation.
respond here for further info.
- john dio -
1helpful
Alesis-sr 16 sound low
Buy the correct adapter that matches the voltage AND current requirements of the unit. MANY universal ones do not and the original MAY have built in filter that universal does not.
You MAY also need to do a factory reset on the unit.
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
