Question about Panasonic PANAFAX UF-6000 Fax
Panafax UF-6000 can send but not receive
I have two Panafax UF-6000s in a remote office that both have the same problem - unable to receive faxes. It can't be a coincidence these two are having problems but the other fax machine (a different brand/model) is fine.
When sending faxes to these two machines, the number rings, the fax machine 'answers' but the fax does not go through. The sending fax machine will continue to resend but the fax never goes through.
The phone line itself is good. An analog phone tests fine. But we can't figure out why both fax machines are having this same problem.
It should be noted this building has had several power outages recently - it is possible a power outage knocked out a setting somewhere?
  • sdravk Oct 17, 2008
    Will this clear out the programming done to the fax machines? Like the fax machine's identifying phone number and stored numbers?
    And once this is done, is there anything else that needs to be done to it? Or should it be good to go?
  • 284 Answers
Sounds like a memory lock up all you should need to do is a all job clear
Posted on Oct 20, 2008
  • Paul Homuth
    Paul Homuth Oct 20, 2008
    doing this will not clear any of your settings
  • 2,120 Answers
Yes, especially if they were active.
Do they show Code 21?
Factory reset them.
Unplug the power cord from the back of the machine
While holding down the ENERGY SAVER key, plug in the power cord.
Scroll down to SHIPMENT SET
press SET
press 2
wait for machine to reboot
Posted on Oct 16, 2008
  • Leroy Elliott
    Leroy Elliott Oct 17, 2008
    Yes, they will be just like they came out of the box
Received pages are cut off
This problem sounds like you have a NOISY or DIGITAL phone line. Press the MONITOR key and listen to the dialtone. It should sound static-free
Your fax machine needs a dedicated ANALOG phone line for optimum performance.
Jun 09, 2009 | Panasonic PANAFAX UF-6000 Fax
I'm unable to receive or send faxes
Are you sure the line is good? You can try a plugging a telephone into the line to check it.
If you press the "hook button" (or whatever it is called on that machine) do you hear a dial tone?
is the phone cord plugged in snugly and in the proper jack on the machine? Is the cord good?
These are a few things to try.
If all of that checks out, then the phone board on the machine is shot.
May 26, 2009 | Panasonic PANAFAX UF-6000 Fax
I have a Panafax 770 when sending fax it reduces the recived fax
Open up the document feeder and make sure of the switches is not trapped in the down position.
May 18, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Need report on total faxes sent and received Panafax UF-6000
function-7-""monitor button press it 4 time"" - then press * [star button] - should say service mode. then press 3 -3 start
Dec 12, 2008 | Panasonic PANAFAX UF-6000 Fax
Panafax UF 770
What happens when you try to send?
Nov 07, 2008 | Panasonic Panafax UF-333 Plain Paper...
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Continuous Fast Busy Signal
Your modem/fax board is most likely bad. there is a relay on that board that has probably failed. It is stuck. I doubt it can be made to work. those are really small relays on those boards.
Jul 07, 2008 | Panasonic PANAFAX UF-6000 Fax
How to enter TSDI on a panafax machine
keep pressing set until you get to OWN ID
key in phone number
Nov 19, 2007 | Panasonic PANAFAX UF-6000 Fax
Panafax uf-790
First see if you plugged the phone line into the line jack and not the extension or answering machine jack, Sounds like it is not plugged into the LINE jack.
Thats the most frequent problem when you can fax out but not in.
Nov 08, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic PANAFAX UF-6000 Fax Logo
312 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
