Question about Nintendo Wii Console
I JUST RECENTLY GOT CABLE TV WITH A CABLE BOX AND I DONT KNOW HOW TO SET MY WII UP TO CABLE BOX SO I CAN PLAY IT.............HOW DO I DO THIHS?
  • 3 Answers
Do you have plug that are red n white yellow just plug put your tv to the game mold
Posted on Oct 17, 2008
Blurred picture on Samsung Dv3 LCD tv
You may need to upgrade to better cables. Here is a good set that I recommend.
480p HD Component Cable for Nintendo Wii
- Matt
Jan 25, 2014 | Samsung Televison & Video
We are trying to set up wii-through the dvr to play on Sharp LC-PD50U-unable to get it to work.
Connect the Wii directly to the TV either using the HDMI cable or the Hi def cable(5 RCA connectors) that come with the Wii. Then select the input number on the TV to get a picture .
Dec 25, 2012 | Sharp Aquos LC-PD50U 50 in. Plasma...
How ca I connect my wii nintendo and set top box together in KLV-32T550A
Look for something like this at your favorite electronics store...http://www.bestbuy.com/site/eForCity+-+3+Way+Audio+Video+AV+RCA+Switch+Switcher+Splitter+with+Cable/4655143.p?id=1218501028155&skuId=4655143&st=AV Switch&cp=8&lp=3
Copy all of that into your browser and you'll end up at best buy looking at a A/V Switch that can switch between 3 different devices so you don't have to change the cables...also, look for ones that are remote controlled that have more options...I just included this one as an example...hope this helps you!
Jun 12, 2012 | Sony Klv-32t550a Bravia Multi-system Lcd...
Why is my Samsung tv only showing black and white picture?
If the normal TV channels are OK then the wrong input has been selected. Probably set to component instead of composite.
Oct 14, 2017 | Samsung SyncMaster Televison & Video
I dont know if it is my wii but my tv is black and white/grey and white what can i do to repair it?
If your TV is only black and white while playing on the Wii, this is indicative of a problem with either the A/V cable or the A/V ports on your television.
If you have a friend who owns a Wii, try using their cable, or change the A/V jacks to a different set of ports on your television.
NOTE: The A/V jacks are the red, white, and yellow plugs that plugs into your Wii on one end and into your TV on the other. If, for example, these jacks are under VIDEO1 on your TV and you switch the viewing mode to VIDEO1 to play Wii, then try moving them to a set of A/V plugs under VIDEO2. If this is an older TV, there may be only one set of plugs on the TV itself. Try the console on a different TV. It may be time to get a new television. This often happens on older TV's.
May 04, 2011 | Nintendo Wii Console
Recently purchased a wii and had no av cable input on my tv, so I purchased a component cable, hooked it up, and only got black and white. After spending two hours messing with both the wii settings and...
You can't use component input on the tv. You have to have component output on the wii and it doesn't have it. Are you sure you don't have A/V inputs on your set? I don't know of any set that doesn't in the LCD field, even the cheap imports have them. I tried to cross your model number and it went nowhere. Could you re-check your model number and send it to me. Some models of Insignia had a hidden compartment on the sides by the antenna jack that pops out.
Dec 27, 2010 | Insignia 42" LCD Flat-Panel HDTV
Video Issue with Onkyo 606 when trying to watch Cable TV.
When this happens and you just see the input label try to press the power button on the front of the cable box and see if it brings the picture up. If this does produce the picture then it is a good possibility that something is interfering with the remote communicating with the cable box. I don't know if you have it contained in an entertainment center or how you have placed your equipment but if there is glass try to clean it and also wipe down the front of the cable box and make sure there is an unobstructed view of the front of the cable box.
Good Luck.
Dec 09, 2009 | Onkyo TX-SR606 Receiver
No Sound from TV when using Component Cables
what you do is plug in the HD cables as you previously stated and then place the red and white cords where you would normally put then like when you plug in a dvd player or the place you normally would plug in the red and white cables.
Apr 16, 2009 | Nintendo Wii Console
Need to install a PS2 to a cable box.
unhook the cable box from the tv and hook that cable into the ant in on the modulator and run the output of the modulator to the tv.set the modulator and tv on channel 3.you may have to turn off the cable box to play ps2.please give me a rating if this was helpful,if you need more help just ask
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Setting up Wii
why dont you hook them up to the tv?
Dec 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
78 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
