Question about Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail
Can Get Windows Vista 64 or 32 booting
I bought a new hardware Everytime i try to install vista or windows XP gives me a Random Blue Screen,  but some times when i accomplish the installation, (At minimun BIOS SEttings)
it wont Boot. and reports a checksum error.
or sometimes, NTOSKRN  Corrupt other times NTDS.SYS corrupt, and keeps going on and on.
What it could be?
Please Help
My specs:
GIGABYTE GA-MA790FX-DQ6 SOC AMD2+  BIOS F6B
CPU AMD PHENOM 9850 2.5 GHZ 95 W 4 MBK SOC AMD (QUAD CORE)
VIDEO POWERCOLOR X1950PRO512MB AC GD
HD SEAGATE 500 GB 7200 RPM SATA II ST3500641
4 Memory Sticks 4 GB DDR II VDATA 800 MHZ
 DVD LITEON LH-20A1S-12 20X SATA
Keyb and Mouse USB
3 Suggested Answers
  • 178 Answers
SOURCE: Troubleshooting
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Posted on Mar 17, 2008
  • 77 Answers
SOURCE: I just assembled a pc
I think this website describes the fix for your problem, please check here
Posted on Sep 03, 2011
I got a new Toshiba L455-S5009 with Windows 7 (64 bit) pre-installed. I want to install Windows Xp. Everytime I run Windows xp installation cd it gives blue screen of death and stops the installation....
I would strongly recommend against downgrading to Windows XP. The hardware in your machine is designed to run and perform at it's best on the newer operating systems Vista/7. You may run into several issues trying to actually locate drivers for your machine.
I have looked on the Toshiba's support site for your particular model and some of the critical drivers are not listed for Windows Xp (sound,video,LAN,wireless)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2601123&rpn=PSLY0U&modelFilter=L455-S5009&selCategory=3&selFamily=1073768663
Not to mention the fact that your system is running a 64 bit processor and you are going to be downgrading to a 32bit operating system and not utilizing your processor's potential.
To answer your question though it is most likely because your system needs a driver for the hard drive controller that is not included on the Windows XP installation media. I did search on the for a controller driver but was not able to find one. Can't say with 100% certainty that is why you are receiving the BSOD but most likely the case
Jun 29, 2010 | Computers & Internet
Windows xp professional won't complete setup.
Its an hardware error. You have tech support with MS since you bought the new XP try to see if they can tell you what is the hardware its complaining about.
Feb 26, 2010 | Microsoft Windows XP Professional With...
Installaion error
First make sure thats what you want to do since xp is no longer made. If you still want to go ahead you have to make sure you have the complete install and directions. You will have to remove vista first. But check the specs if you bought the computer with vista already installed you will not have the right drivers in your computer to go backwards in versions. Good luck. The reason the error comes up is that the install is trying to remove a component that is needed for your computer to operate. If you had xp and updated to vista, depending on how it was installed it would have removed the xp driver when updating.
Sep 05, 2009 | Foxconn K7S741GXMG-6L Motherboard
Acer Extensa 4630z won't reformate
Yes it is nothing to do with hardware problem of yours, here is a tip to install your windows xp on your ACER Extensa, but before that I tell you that your hard drive inside is Sata so this is the solution, go to your BIOS Setup and change the setting of your hard disk from SATA mode to IDE Mode, find it their., and have your installation with your new windows xp, trust me, good luck!
Jul 26, 2009 | Computers & Internet
Unable to install winXP on my new HP Pavilion dv5
this problem is hardware inside your PC.. or unable to detect the device for the installation of your new system
Jun 16, 2009 | HP Pavilion DV5234US Notebook Laptop
Insataling windows xp problms
If u just want XP . Source a dos boot ( u can get files from internet), format the HDD .create main partision for windows xp and try installing
May 22, 2009 | Computers & Internet
Hard drive is not recognize by the computer
Both XP and Vista have this feature that requires that new installs of hardware be certified by Microsoft within anywhere from 30 to 60 days from installation.
Run an install (not a clean install which will wipe your data, mind you, but an install accomplished by installation disks, where you will be asked which kind of install you wish to accomplish, and you will be asked to register your software using your product key)
If you need additional information, I will be more than happy to assist you.
Apr 07, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
How can i install windows xp sp3 in compaq presario cq60-104tu.
Ok it must be one of this problems:
1) you had vista, you wanted xp for whatever reason. you are doing a fresh install using the service pack 3 disk. there is hardware combatiblity issues and must stay with vista. this is becoming more common with the life of xp coming to an end.
2) you had xp and are reinstalling and hardware has failed.
3) you had service pack 2 or before and are updating your service pack and there is some issue with hardware or software.
Jan 16, 2009 | Compaq Presario Notebook
Failed vista uninstall
do install the vista only, coz xp could not recognize the sata hd, it gives the blue screen error, if u want to install xp otherwise, install sata divers from the supplied disk with computer.
Nov 21, 2008 | Acer Aspire 5920-6727 Notebook
Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail Logo
53 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
