Question about LG WM-2277HW Front Load Washer
LG WM1832CW Just bought a house that came with an LG WM1832CW Direct Drive System, washing machine. It gets stuck at the rinse/spin cycle... it just keeps spinning intermittently and/or I get an LE error message. Is there somewhere I can download a user manual for this machine. I also have no idea how to operate the LG dryer either... a user manual for that would be really helpful. I contacted LG and they told me I'd find a manual online at us.lge.com but there is no manual available for this model. It is a LG DLE2532W. Thank you in advance, for any assistance you can provide. Much appreciated, Linda 360.927.2428
  • llshannah Oct 19, 2008
    Thanks silver top... will give it a shot!
  • Anonymous Mar 27, 2014
    I NEED FREE USER MANUAL FOR ABOVE MENSION PRODUCT
  • 566 Answers
Hi linda from what you describe? the machine does wash cycle? but won't spin cycle? if the machine is a couple of yrs old ? it may well be the motor that runs machine is in need of some new brushes fitting ? they are not expensive and may be worn too low to activate the higher revolutions needed for spin cycle it is not a difficult job to drop motor off and check/replace if you have a good male/ friend? with elec competence ? have found this problem on other machines and most recent zanusi cost £5 for 2x new brushes as apposed to the £££££s the lady was estimated for a timer ? by plumber so why not check it out b4 you part with money ? best wishes/luck
Posted on Oct 19, 2008
In rinse cycle the cold water hose is making a heck of a noise,
Check the screens on each end of the filler hoses to ensure they are clean and sand or rust free.
Mar 09, 2016 | LG WM2101HW Front Load Washer, White, 4.0...
LG WM1832CW, what is the key code combination to cause it to spin only?
The machine has a "Rinse & Spin" button in the "Options" side of the control panel. Press this button to accomplish the spin "cycle" that you require.
Oct 12, 2014 | LG WM-1832C Front Load Washer
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
Washer wont drain lg tromm frontloading washer
You need to isolate the drain pump and check the voltage at the time of the drain cycle. If no voltage is present then you need to check on the control board as it can be a failure of the drive.
If voltage is present but there is no drain action then the valve pump is stuck, choked or faulty.
remove and check: click on : Drain.
Feb 27, 2013 | LG WM2016C
My WM1832CW front load machine consistently gives me the UE error code during the spin cycle regardless of the contents or size of the load. Its a direct drive system - so what could be the problem?
bad imbalance sensor. silly little contraption that sticks off the back of the drum. It is a plastic lever with a light sensor attached to the end. there is a hole and a bb that sits in the hole. when the load gets imbalanced, the bb gets knocked out of the hole and the light shines through the hole. the light sensor relays the error to the computer and it displays UE. I took the sensor apart, and put a piece of tape over the hole so the light cant shine through anymore. No more UE code. LG parts are very hard to find. I dont mess with them, but it was my neighbors machine. This will get them by until they can buy a new washer. good luck.
Jul 20, 2011 | LG WM-1832C Front Load Washer
Spin cycle isnt spinning. it will spin slowly during rinse but not spin cycle
Are you receiving a "LE" error code on the display? If so, you'll possibly need a Hall sensor or Stator assembly replacement. If you have your units date of purchase, it will possibly fall under the 7 or 10 year warranty on the direct drive assembly which includes hall sensor/stator/ and the rotor.
You can refer to LG for service if you'd like.
Mar 07, 2011 | LG WM-2277HW Front Load Washer
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
LG wm1832cw shaking bad in spin after move
manual,,lg.com...but befroe youdo that,,put the unit in spin ,,get a small wrench or the wrench that came with the installation pack..now when unit goes into high spin the fastest spin,,tighten the lock nuts on the legs one at a time dont turn the leg itself,,just the lock nut on the legs,,it might take two spin cycles but you will get it ..tighten all the way uop to the base,,,onthejob
Jan 09, 2009 | Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
690 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
