Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 front load
What is f35 error code? and what is sud error code?
I had the same issue with a brand new wash. The issue I found was the installers installed the drain line too low. The drain line needs to be a minimum of 39" above the floor. Hope this helps -- Kent
Posted on Nov 11, 2008
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Kenmore elite front load washer model 46752701 after replacing pressure control switch i still get f35 code
Most common cause for the F35 error code: Using non-HE detergent. Detergent slime builds up in the hose, eventually getting into the analog pressure switch and killing it. Make sure you flush out as much soap as possible and make sure to use HE soap or it can keep occurring, also some vinger can calm down the suds
Oct 26, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
My kenmore elite he3 comes on when i start it .a little water comes out than it strarts making a buzzing noise and wont stop unless i hit the pause button
DO you get a code on the from display of the machine? If it says F35 or SUD you have a water pressure sensor failure. You can but the sensor on ebay for about 54$ Its very easy in install also.
Oct 24, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Has code F35
I just got the same error code F35 and sometimes it says SUD. Help pls Kenmore HE5 Steam Washer.
Nov 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
546 people viewed this question
Sal De
fordexpert
Robert Rankin
