Question about Maytag LAT2300 Top Load Washer
Washer fills up, motor hums, but no spin.
Everything works but the spin. It just hums.
  • 82 Answers
Sounds like the drive belt is broken these models have pump belt and a drive belt
Posted on Jan 04, 2009
The washer will fill up with water but it wont start washing or drain or spin you hear a humming noise then everything stops. Then in about 5 mins it will hum again then stop again
If the washer will not agitate, spin or drain it's a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction. The reversal of the polarity is controlled by timer contacts 7 and 14.
Most likely it's a timer or loose wire connection.
Jan 22, 2011 | Estate ETW4400VQ Top Load Washer
Washer not spinning
If you are neither spinning nor agitating and you can hear the motor running (humming or buzzing) the the problem is with the coupling. See the first link below to repair.
If the motor does not run, only fills, no drain, no buzz no hum then the problem is most likely with the lid switch, see the second link.There is video near the bottom of that page showing how to replace it. Let me know if this helps.
Coupling
Lid Switch
May 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
My washer will not drain but everything else is working on it can u give me instructions?
most of the time it is the door switch that gets damage when the door slams. if its only fill with water but not turning then it is defently the door switch.
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
My washer will fill up and drain but not agitate or spin
Looks like the motor needs to be replaced. After some years of use, the motor may not have enough strength to move the drum. If you test the motor by itself, it may work, but can't handle a load.
Sep 19, 2009 | Hotpoint Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How do I find model number?washer just hums
Check the motor or the tub bearing. Something is frozen on your machine and not letting it spin. You can also check the brake or clutch and make sure it is not stuck. On the back of the unit when you remove the back panel you will be able to see everything that you need to get at
Feb 13, 2009 | Kenmore 15864/15862 Top Load Washer
Roper washer will not spin or agitate
Your coupling between the gearcase and the motor has broken. Go to a appliance parts store and ask for a whirlpool washer coupling. Remove the cabinet by taking the 2 screws out just behind the control panel.
remove the whole cabinet.Everything clips together. Pump first, motor, and then coupling. BobH
Dec 04, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
264 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
