Question about Bakers Pride BAK-DS805 Gas Single Oven
Pizza oven bricks need to be changed
One of the bricks in our pizza oven is cracked. couldn't figure out how to take the brick out to replace.
it is gas powered.
  • 21 Answers
You must use a long crowe bar lift the brick and pull it out need the size of the brick to let you know how much and where to get it if it a 2inch thick they are no longer sold most lilkely it 1 1/2 inch
Posted on Nov 25, 2008
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
Old timer wood stove manual
I need to find a owner manual for an old timers wood burning stove insert or at least how to replace the fire bricks
Jan 07, 2014 | Ovens
Build a pizza oven in the back yard
Hi.
All you need is bricks and cement.
Use perforated bricks or regular 65mm bricks for the support. A light oven may be built on an U shaped support (you will need to make some structural considerations about the weight). Moreover the U shaped support on top requires an armed concrete slab adequate to support the chamber. If you are not sure about structural performance, build a solid support block of bricks.
Make sure that the support is adequate for the weight of the heavy chamber. If the oven is big, then lay basic foundations or build the oven straight on the ground.
For the chamber you must use refractory bricks (fire bricks). You have different choices of design. A common shaped that do not require armed concrete parts is the igloo style chamber. Leave space for the chimney on top of the chamber.
Mar 24, 2013 | Ovens
Do you sell outdoor brick oven doors?
No, we just give advice on how to fix stuff...
Do a search for "outdoor brick oven parts" and see what comes up...
heatman101
May 11, 2011 | Ovens
Pizza dough spilled into top of oven.
Pizza sauce tends to be highly conductive and corrosive. If it got into the keypad or control board it is probably causing a short. It may be able to be carefully cleaned with alcohol but some disassembly is required.
Jun 26, 2010 | Fisher and Paykel AeroTech - OS302M...
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and sandwhiches. We are planning to have pizza. Is anyway you make adjustment for Pizza
Dipending upon what kind pizza you want to use.
Subway using the same toster to Bake personal pizza (90 Second for 1 and 120 sec for 2 pizza
Oct 17, 2009 | TurboChef TORNADO Electric Oven
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Jul 15, 2009 | Ovens
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
Bakers Pride BAK-DS805 Gas Single Oven Logo
263 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
Paul Carew
Dan Webster
Dan Webster
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
