Question about Canon GL2 Mini DV Digital Camcorder
Using GL2 as a webcam
Is it possible to use my Canon GL2 as a webcam, if so what do I need to do? Will my computer recognize it as a webcam? How would I hook it up?
t
Using the firewire/IEEE cord attach the camera to your computer.  If you are using a Mac it should instantly recognize the external camera when you open iSight or what ever utility you are using to communicate.  If you are using a Windows based computer open MS Moviemaker and it will recognize the camera as well by selecting capture -- once the camera is recognized you should be able to broadcast with it.  If you are using uStream.com sometimes your video capture interferes with the ability to broadcast.  In that case hook up the camera using firewire, connect to uStream -- grant uStream permission to capture using the camera then you can see the video in your browser window.
Posted on Nov 19, 2008
  • jbaerncopf Jan 10, 2011
    and what do you do if it does not recognize your camera?
How to connect canon gl-2 camcorder to computer
Are you using the proper Firewire cable to connect? Also, the GL2 has had issue with the Firewire port going bad. Try a different cable and see if that helps. It can't be a USB-Firewire cable either.
Sep 07, 2014 | Canon GL2 Mini DV Digital Camcorder
Tip
Canon GL2 Manual Download
Download Canon GL2 Camcorder Manual
Have you misplaced your Canon GL2 Camcorder Manual?
Would you like a digital, searchable, pdf version of the Canon GL2 Camcorder Guide?
Follow this link (& click FREE) to download a pdf version of the Canon GL2 Camcorder documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Video Cameras
Tip
I hope that helps.
on May 08, 2010 | Canon GL2 Mini DV Digital Camcorder
Video from Canon GL2 to my sony vaio windows vista and I already updated to zoombrowser EX 6.1
Suggestion: Remove the memory chip from the Canon and get a reader that plugs directly into your USB port on the vaio. Available online or at any computer shop or big box store. You should be able to open the photos directly from the chip. They'll be in a DCIM folder - you may have to easter-egg around a bit, or search for *.jpg
Lots faster and less frustrating than the camera's software interface.
Aug 02, 2017 | Canon GL2 Mini DV Digital Camcorder
How do I get a canon gl2 to work in skype?
Connect your Canon camcorder to your computer using the firewire cable.
Allow your computer to recognize the device and automatically set the appropriate configurations. If your operating system does not automatically install the drivers for the camcorder, then you must install them manually, using the CD that came with your camcorder.
Open Skype and navigate to the "Preferences" menu under "File" or "Skype" -- depending on which operating system your computer uses.
Select "Video" from the preferences menu and click on the drop-down menu next to "Camera."
5
Select your Canon camcorder device name from the list of available options in the "Camera" drop-down menu.
6
Close the preferences menu to save the new camera settings and begin using your Canon camcorder as the video source.
Feb 04, 2011 | Canon GL2 Mini DV Digital Camcorder
I lost my canon gl2 solutions disc and need to download a new one. Does it come in updated windows versions like vista?
Quick thought... the disc that came w/ my GL2 was only for downloading pitures from the camera and nothing else... Not much use...
Feb 02, 2010 | Canon GL2 Mini DV Digital Camcorder
Computer no longer recognizes my G9
A POSSIBLE SOLUTION:
i have the same camera but i want to use it like a webcam.
I found a driver that is located in the canon homepage, called "canon RAW codec"(compatible with Vista and XP), and it allows you to download the photos of the camera and to take fotos instantly, but it don't suport the webcam function...  :(  . I'm using it in windows XP.
That's all, Ithink that it must work for all the users.
Mar 30, 2009 | Canon PowerShot G9 Digital Camera
BLACK SPOTS CANON GL2
normaly whatever editor you are using will be able to import it. windows moviemaker is preinstalled on all pcs so thats free and you can use that.
Jun 11, 2008 | Canon GL2 Mini DV Digital Camcorder
I need to get the video from my canon gl2 to my pc (free sofware0?
You cannot use USB to transfer video, the USB is used to take pictures on/off among other inserts. You have to use the firewire to transfer any and all video.
Jun 05, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon gl2 camcorder, how do i download my film to vista
I'm having the same problem. I don't have the disks with the camcorder and Vista is not recognizing nor seeing the camcorder. I'm going to try to download Zoombrowser and see if that makes it work.
Apr 07, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
1,087 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
