Question about Estate TAWS800JQ Top Load Washer
Clips are falling off from into the tub
How do I get the lid off to put the clips back on?
  • Estate Master
  • 8,220 Answers
I have the solution: HERE
Posted on Mar 03, 2009
Top drawer is hanging up on something
The only way to fix this is get the drawer out by
1 Open the drawer fully.
2 Depress the right-hand tub clip and push it back about 30mm (1
inch). Repeat for the left-hand side.
3 The tub may now be lifted up off the drawer runners.
4 Slide both runners back into the product.
5 Refit in reverse manner.
That way you can get access to the top seal - which is called the lid.
You will have to see how much of the lid is still left behind hanging on the top.
To remove lid
1 Remove tub assembly as per earlier instructions
2 On the right-hand side of the lid release the two tabs that clip the lid
to the yoke. Repeat for the left-hand side.
3 The lid is now free to slide out of the chassis.
4 Refit in the reverse manner taking care that the lid is fitted the
correct way around. The front is indicated on the top of the lid.
If the whole lid is intact then it may be a matter of fitting it back. Othwerwise you will get one from fisher and paykel parts
To fit the lid back you will have to check if the actuator yokes are not broken. In which case you will have to take these out and replace with the new one. (comes as part of lid kit if you buy it).
Remove Yoke
1 Remove the lid as per instructions above.
2 Release the lid actuator connecting arm from the bottom of the yoke
by squeezing the two tabs towards each other.
3 Slide the front of the yoke downwards at an angle until it moves out
of the track in the rear of the trim, and is clear of the chassis flange.
4 Refit in the reverse manner taking care that the yoke is the correct
way around.
When putting back you will need to align the lid actuator motors on both sides correctly so that the yoke moves the same distance when activated. Otherwise the lid will have a scew.
Hope all this helps. If unsure you will need to contact a technician.
Jun 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I access drain pump
take out two screws on top control panel,either in the back or in front or you might have to pop off covers on left and right side of panel and then you'll see screws,the panel is on hindges,lift it up,now you'll see two metal clips put screw driver in the front part of clip and push screw driver back towards panel and clip will release,remove lid switch wire clip and pull the frame to you and move it out of your way,look down under the front of tub and remove the two metal clips holding pump on
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Getting off the End Caps
The end caps do not come off on this type of control panel. There is a retaining clip holding it in place at each front corner. You need to insert a putty knife between the top panel and control panel at the left and right front corners. Push the knife straight in from the front and push to release the retaining clips while lifting the panel. Once both clips ar released, the panel will open up. You can view a diagram of the console at searspartdirect.com. Just type in your model number and look under the "Control Panel Parts" heading. The retaining clips are listed as item number 8.
NOTE: Sometimes the clips will come off and fall down inside the washer cabinet. If this happens, you may be able to retrieve the clip by moving the washer and looking underneath. However, if it becomes caught somewhere inside the cabinet, you will need to remove the exterior cabinet to retrieve it. Just follow these steps:
1. Unplug washing machine.
2. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
3. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
4. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console by aligning the retaining clips with the holes on the top panel and pushing straight down until you hear a "click".
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Sep 18, 2009 | Washing Machines
How do I remove gravel underneath washer tub?
To access the washer:
  1. Use a putty knife about an inch wide.
  2. Push the putty knife on the sides to release the top panel and lid clips.
  3. Lift the top panel back towards the wall.
  4. Tape the lid so it does not fall back and chip.
  5. Remove the two 5/16 inch screws on the inside of the front panel. The top of the front panel will come towards you.
  6. Lift the front panel off the clips on the bottom and set aside.
  7. Pull the washer out from the wall and lift up the front to access the belt. Support it with a block of wood.
Aug 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have a Kenmore 900 series washer. It fills with water but them doesn't run. I see no switch on the lid but if I lift and shut the lid sometimes it will start. This is getting worse.
There is a lid switch which is proabably going bad it is located at the rear of the lid lift the lid up all the way look where the lid touchs the tol at the back in the middle you will see a little tab sticking out which when you close the lib the lid presses down on this tab which makes the switch function. You have to take off the top of washing machine to replace switch. Unplug washer before doing this
Aug 07, 2009 | Kenmore 24052 Top Load Washer
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Replacing motor coupling
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
I threw in a load of 3 small rugs. When I returned to check on them, there was water all over the floor. I immediately checked the drain for clogs, and there were none. I started another load, and as...
u can remove front panel by taking a putty knife and push back clips located in between the top panel and front panel. the front panel will fall towards you at the top. lift panel up to remove it off of the hinges at bottom. u should be able to expose the tub and everything else inside the cabinet of washer. put washer on small load and start the cycle. should not take long to find out where the water is coming from.
Jun 22, 2009 | GE Profile WPRE6100G Top Load Washer
Replacing lid on old Maytag toploader
pull the lid back at angle and they will fall into tub.put one side in wet the other side and try to put ball on lid and slide it back into slot for lid ball.may be a hasssle but it will go into place.
Mar 09, 2009 | Maytag PAV2300 Top Load Washer
Water runs back into tub when lid is opened
not sure what you by opening lid and a large amount off water falls in.i think you mean you open the lid and see water there.If thats so two things one your pump is blocked,youll need to confirm by watching whats happing.Other is the water valve is not sealing so water is dripping in all the time.you would see this when standing there be patient
Dec 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
18 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
