Question about Panasonic NV-DS60 Mini DV Digital Camcorder
It's me again with the Panasonic NV-DS60
I'm the one with the problem about the viewing/filming is super super fast... and the noise from the wheels
first, thanks for your help =]
ok, so now when i try to close the casette box, it also makes very loud noise (like wheel noise) i'm able to close it though.
now, i don't understand which ribbons you're talking about. do you have a picture?
loud clicking - i'm not sure what clicking is, but there are two noises:
1) a very low buzzing noise, that is heard all the time when the camera is ON
2) a loud spinning noise, probably from the wheels spinning very fast
what do you mean "run it from main"?
not wet, nope
well that's all.
  • 33 Answers
OK, so we're getting closer!
I find that those with problems that manifest themselves on closing the cassette door are related to a loose ribbon connection(s).
Sorry, no pictures, I fixed mine and sold it!
When I say run from mains, I mean there was a cable in the original box that connected from the charger base into the camera, to give it a constant electrical supply; you can remove the battery and run it like this.
This was just to prove that the battery hadn't gone haywire and simply caused a malfunction.
Personally, at a guess, I would definitely open it up and wiggle the ribbon cables, while you're there you should also clean the moisture sensor...just incase.
1. Cleaning the moisture sensor:
Take the base cover off by removing the 4 screws (3 on base - 1 under LCD). There will be two small copper contacts under this cover toward the top/middle. Either just blow on them or if that does not work clean them with alcohol spirit or similar, put the think back together and power up and that should do it - worked for me.
2. Ensuring ribbon cables are seated correctly:
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you'll be happy then!
Good Luck
Posted on Oct 16, 2008
MY PANASONIC CAM RECORDER STOPPED WORKING BECAUSE
The tape will be badly damaged if trapped in camera, this always happens when the camera has got dirty heads and capstan rollers, some times the door wont open if this happens, but if it does open your local camera shop may get the film out.
Jun 16, 2010 | Panasonic NV-DS60 Mini DV Digital...
How to transfere films from my panasonic nv-ds60 to pc
Hi
Install a PCI TV Tuner Card in your PC, connect your panasonic nv-ds60 to that pc tv tuner card, and record..
thats all
Aug 03, 2009 | Panasonic Cameras
Connecting NV-DS60 to a computer
it should be connected with a computer because almost all camcorders have a connection to it by using USB. First install the CD driver from camed with your camcorder's box to your computer and after that connect it with a USB. it should be recognize the camcorder after you insert it. you can check also your camcorder's manual.
thank you for using fixya
CHARCOIS
Feb 19, 2009 | Panasonic NV-DS60 Mini DV Digital...
Dew symbol on panasonic NV-DS60
My panasonic camera does the same- from what research I've done online the only method (that REALLY works) is removing the battery pack and hitting the camera (where the battery was at, don't hit it too hard) with the palm of your hand. I didn't believe this until I tried and *poof* it worked back normal.
Nov 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
Help for Panasonic NV-DS60 video camera
J4AI EU UN PROBLEMES AVEC MA CAMERAS PANASONIC NV-DS60,QUI CLIGNOTE SENT A RAI.ET QUI NE MARCHE PAS
Jul 04, 2008 | Video Cameras
Connecting my nv-ds60 to my computer
plisss send my draiver camera video panasonic NV-DS60
May 06, 2008 | Microsoft Windows XP Home Edition
Panasonic NV-DS60 Mini DV Digital Camcorder Logo
152 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
