Question about Whirlpool GGQ8831L Gas Dryer
How to insert a thermal fuse
I HAVE A STACKABLE WASHER DRYER AND CAN'T FIND WHERE TO PUT THE THERMAL FUSE...PLEASE HELP....210-739-2211
    President:
  • 1,462 Answers
Take top off and thermal fuse is clipped onto the dryer manifold.
how do you know you need one if you can't find the original and test it?
Posted on Oct 16, 2008
Maytag Neptune stackable washer/dryer dryer not heating up?
check house braker, element, thermal fuse, thermostats, wires and connections including to the motor as the motor switch acts on the element. if all is good your electronic board should be the problem.. a local part dealer will usually help you in testing your parts if you dont have a multimeter..
Jan 28, 2015 | Maytag Washing Machines
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Where to locate dryer circuit, I think fuse needs changed. Dryer runs but no heat. Stackable set, dryer on top.
kill the power by unpluggin of kill breaker get acess to inside usually from back check the thermal fue or themosats or heating element.. clean your venting as well there might be a tech sheet inside but yea start there.. u can test those with a meter for contunutiy or call for service
Jan 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer of stackable washer/dryer stopped heating... is it fixable?
yes tis unit is fixable the most common problem is one of the thermal fuse has gone bad.the heating element could also be bad.
does the unit still run and you just have no heat check the above items this should take care of you problem.
Sep 18, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Glow bar not turning on- replaced and same problem.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks
May 25, 2009 | Kenmore 72822Gas Dryer
Dryer follow up
I don't know if I was the one to answer your question before but I will be happy to help you. I am not too sure of where your thermal fuse is as I don't know what type of dryer you have. If it's like the one in the picture that I see I would say that your thermal fuse is in the front. There should be a front panel that you can remove and the thermal fuse is located on the heating element housing. You can purchase one at your local appliance repair shop and if you don't have one of those you can get one on line. You might even be able to get on from Sears Home Repair Service if you call them. They may be able to sell you one from their trucks. If it is on the back though you will need to remove the back panel. I can't suggest how to do it as I don't know what your set up looks like. You would have to do whatever you needed though to get to the back if that is where the thermal fuse is located. Check the front first though to see if it is there, chances are that it is. It will be a small little fuse with two wires coming off of it. It is held down with two screws. It is rectangle in shape too. Let me know if you have any other questions and let me know if this was helpful. If you do have any other questions just respond from this message here, that way I will get the message. Good luck.
Jan 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Whirlpool Duet Stackable Dryer
check belt ..there is a broken belt switch also ckd thermal fuse .this is the white do hickey behind the lower panel behind the lint screen housing if a vent problem occurs this fuse will blow and unit declines to operate
May 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Jan 27, 2008 | Dryers
Whirlpool GGQ8831L Gas Dryer Logo
82 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
