Question about Logitech Cordless Mouse
Every kind of mouse won't work!
I was in the middle of working today when I must have typed something on my keyboard that made the mouse stop working. I was using a Logitech wireless mouse (and keyboard), so I tried to reconnect it. Then I changed the batteries. All to no avail. Then, I tried to plug in just a normal USB, old fashioned mouse. Still didn't work. How can I fix this problem (bearing in mind that I can't navigate to new places like the control panel and whatnot without a mouse)?
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Was it possible you held the shift or control key down for a long time? You may have activated Sticky Keys by accident.
    Shut down the PC. From a cold start press F8 after the bios beep and tap that keytop like a piano key to get to a Safe Mode boot menu. Choose Safe Mode and the acknowledge the OS installed by pressing enter. Once in Safe Mode, you should be able to get to control panel using the keyboard. Go to handicapped features and disable sticky keys as a feature. Set your mouse to generic logitech wireless or even MS wireless. Reboot, at a desktop sync your mouse transmitter and mouse to a channel and you should be okay.
    You may have to use System Restore to go back a day or less, before this all happened if the above paragraph doesn't get you working again.
    Any questions, use the comment box below to ask away.
    Regards,
    Worldvet
    President:
  • 8,637 Answers
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 19, 2009
My wireless keyboard won't work
Maybe something crash with your OS. You can reinstall it maybe :D
Mar 14, 2012 | Computers & Internet
Slow or none response time for HP Wireless Keyboard
You might want to check the batteries being wireless, also check the device conected to your tower that reads the keyboard, make sure its pushed in all the way or not being disturbed by any objects.
Apr 21, 2009 | HP Keyboard & Mouse
Keyboard connectivity
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Also to Rest/Connect the mouse, turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Nov 30, 2008 | Computers & Internet
Logitech keyboard quit working
hi,
almost every wireless keyboard / mouse has a connect button somewhere. its located on the bottom or on the side. what you need to do is to press and hold on the connect button to synch the device with the transmitter connected to the computer. if the transmitter on the computer has a connect button you might need to press them both at the same time. do the same if the wireless mouse stops working.
Oct 16, 2008 | Logitech Cordless Desktop MX 3000...
Keyboard stopped working
Have you replaced the batteries?
Then, Normal 0 Press the Receiver button (and the lights will start flashing.
If the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Then they should work okay.
Aug 27, 2008 | Kensington PilotBoard 64385
Mouse does connect but keyboard does not, vice versa
reinstall the logitech cd which came with keyboard and mouse, with the mouse pluged in. once reinstalled restart and while restart plug the keyboard in..... this should resolve the issue.
May 29, 2008 | Logitech Cordless Desktop MX 5000 Laser
Keyboard stoppped working
I had the same problem. Some keys on the keyboard would work, others not. It seemed to happen after an update to the SetPoint software. I got it fixed! I tried everything and in the end this is what worked:
1. I started the computer and obviously could not log in.
2. My mouse worked, my standby key worked, but no other keys.
3. I used the mouse to activate the on-board keyboard in Vista (left bottom corner).
4. I put in my password and logged in.
5. I opened up an app (Excel in my case) to try to type something in.
6. As soon as I hit a key a Logitech wizard for encrypted communication came up!!! It asked me to press the connect button and then enter a code it displayed (keyboard worked at this point).
From this point on the keyboard worked!!
Note to Logitech.... great job on the extra security... bad job on the implementation... if your wizard runs after a PC is rebooted that has login passowrd protection.... how are the users supposed to log in??
Note: My logitech upgrade hung... with mouse and keyboard becoming unresponsive so I had to do the hard power off... maybe the wizard was meant to run after the upgrade before I had to force a restart, but this is something that should be taken into account as well.
Mar 14, 2008 | Logitech EasyCall Desktop 967689-0403...
Wireless key board
Have you tried re-setting the frequency for one of the devices? simply click the button on the infra-red unit then click the button on the back of keyboard and notice the infra-red unit stopped scanning.
Oct 23, 2007 | Logitech Cordless Desktop EX110
Logitech Cordless Mouse Logo
126 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
