Question about Whirlpool Dryers
Dryer will not start.
The light bulb inside the dryer blew out (burst). I replaced the buld and now the light stays on constantly and when we push the start button we get three beeps but nothing else. Any ideas?
  • ncugafan Oct 19, 2008
    Hey jsrock,
    I am having trouble getting to the switch to replace it. Any help?
    Thanks.
  • ncugafan Oct 23, 2008
    jsrock516,
    Your solution was dead on. The switch did not need replacing but it had just come loose for some reason, maybe when the light blew. I have to admit that it was quite a pain to get to it. Maybe I did not do it exactly the correct way but atleast it got fixed. Thanks again.
  • 5,911 Answers
Check your door switch. It sounds like the door switch is not engaging (closing properly). If the switch contacts stay open, the interior light stays on the dryer will beep when you attempt to start it. This is the push button toggle switch on the door frame. This is a common symptom of this problem.
Open the door and push in on the switch, If the switch is working properly, the light will go out. If it doesn't, you will need to make sure the switch is not loose. Next, check the wires leading to the switch to make sure they are not loose, broken or grounded to the case anywhere. If all the wiring checks good, you will need to replace the switch. This is a very simple repair. Let me know if you require further assistance. I hope this helps you.
Posted on Oct 16, 2008
  • Jeff Rockwell
    Jeff Rockwell Oct 19, 2008
    Please post back with your COMPLETE model number (located around the door opening) so I can research and find the information you need. All Whirpool dryers are not configured the same and can differ in design from model to model.
we had a very similar problem on our DLE3777W LG clothes dryer. It would power up normally, all drying options and speed and heat selections behaved normally but when you tried to start the dryer the start button and the time remaining indicator would flash until the unit was turned off. Called LG and Best Buy and they could only tell us to contact a repair shop. But I realized that the light was burned out inside, so I replaced it myself to avoid being charged by the technician I was about to call. The burned out light bulb WAS the problem, as soon as it was replaced the dryer worked perfectly. I think I saved a couple of hundred dollars with a $4 light bulb. I would have been mad to have the technician show up and charge me $120 just to show up, then an hourly rate and then the bulb.
EJ
Jun 07, 2010 | LG DLE7177 Dryer
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dyer has power but doesn't start
dryer inside is very hot, 6 years long time, i have the feeling that wire was damaged and connected to each other cause this kind problem.
Jul 06, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet Dryer (2yrs old) Light buld died and dryer won't start. We changed bought a new light bulb but the dryer still doesn't start. The computerized buttons still litght up though.
Sometimes when a bulb goes out or is replaced the unit can short out.
Try holding your end of cycle signal button for 5 seconds, watch the light, if you control lock it, it will light but will not run because control lock is a safety feature.
Also try pushing door in and starting it, might be bad latch
May 02, 2008 | Dryers
Three beeps
Replace the bulb and door switch.. (cheap)
last would be this 3-beep problem..
http://www.youtube.com/watch?v=tq3k22cqjR8
Mar 27, 2008 | Kenmore Elite HE4 Electric Dryer
My dryer did the same thing, all the lights worked on front, but the bulb was out inside. All I had to do was to replace the thermal fuse and replace the bulb if you want light. The bulb don't have to work in order to dry clothes
Jan 03, 2008 | Whirlpool GEW9250 Electric Dryer
Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
Dec 08, 2007 | Dryers
Dryers Logo
137 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
