Question about Frigidaire FGB24S5A Gas Single Oven
Pilot Light - Frigidaire Model FGF326ASF
How do I light the pilot light? I am experienced with this type of stuff but dont know how on this particular unit.
Thanks...
  • ashlynbl Nov 21, 2008
    regulator problems. how do i turn on or off?
  • 750 Answers
Hello jaronwayne
Welcome,
That range does have sealed burners.
Are you sure it has a pilot light and not Electronic ignition?
Where I live , if we call public service they will come out for free and light it for you!
I'm checking that model and I'll get back to you!
Huuum
Posted on Oct 19, 2008
  • Neil Golan
    Neil Golan Oct 19, 2008
    This range can be gotten with or without a pilot
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316257511en.pdf
My oven stopped working on my frigidaire range. All top burners still work. What could be the problem?
Can you clarify a couple of things for me please:
Is this a gas hob and gas oven, or is the oven electric?
If it is gas, does it have a pilot light? (and is the pilot light on?)
If gas, does the oven light for a moment and then go out or does it not even light?
Jul 10, 2011 | Frigidaire Ovens
Oven pilot light is lite .but oven does not ignite.model# mpf300pbwc
Hello, The thermocouple may have buildup on it. Try to chean the thermocouple which is the small rod going through the oven pilot. You will have to blowout the pilot and clean the thermo with fine frit sandpaper or some guys use a dollar bill. Just shine it up light the pilot and see if it lights.
Jun 06, 2011 | Frigidaire Ovens
Pilot light not workimg
. You light the gas escaping from the tube, and it burns all the time.
Mar 11, 2011 | Ovens
Dont know how to light oven with pilot light
So-- your oven DOES have a pilot light?
Most ovens today, use ignitors-- not pilots--
However, if yours does have a pilot, Here is how we used to light ours back home many years ago.
We pushed in on the oven's thermostatic (Temperature control) knob.
(Note-- that knob connected directly to the main gas valve-- so by pushing in on the knob, we were by-passing the safety's---
There was a little hole in the center of the oven-- bottom pan...
We had to have a match lit, and ready to go when we pushed in on the knob--
We inserted the burning (Wooden) match into the hole, and 'WHOOSH'!-- the pilot lit with a rush of gas and air-- It used to scare us kids!-- But Mom was brave!
I hope this helps--
But if you need more help, let us know--
Mack B
Jan 19, 2011 | Ovens
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
My gas was recently shut off for repairs from the gas company, now its back on and i dont know how to get my oven or stove back on
Ok you did not mention if your oven or stive had pilot lights or igniters. Given you asked the question how too turn it back on I have to assume it does not have electronic igniters. You need to light the pilot lights. There are 2 in top that are between each of the 2 burner sets. If you can not gain access to the pilot light by lifting the top of the stove up you can use a fire starter type lighter and re-light them. Sometimes they will self light if you just use a match on the burners.
As for the oven you can gain access 2 ways to the pilot light. One is to unlatch and remove the oven lower inside panel. The pilot light will be near the burner head. Just light it. The other is to remove the broiler drawer and reach way back in there to light the pilot light.
Again if you have igniter ignition all you have to do is turn on a burner or the oven. Good Luck.
Jan 22, 2010 | Ovens
Where is the pilot light located
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Dec 15, 2008 | Frigidaire FGB24L2A Gas Single Oven
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
1,168 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
