Question about Sony VPL-CS7 Multimedia Projector
Sony vpl cs7 lamp cover problem
I saw the following question from you back in 2007. I just want to know if you manage to fix it, and if, how,  since we now have the same problem.
thanks MF
posted by m_kc on Dec 13, 2007 Report abuse
The lamp cover is half open and half closed. I switch the projector on and the lamp indicator light flashes - the projector works for about 10 seconds and displays the output image on the wall but then the on/off button flashes green constantly and it stops projecting.
Is this easily fixed?
thanks
  • musclemonkey Jan 08, 2009
    I have the same problem.... My projector turns on and stays on for about ten seconds before switching itself off... the lamp cover light is on.
5 Suggested Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
Marrie
  • 563 Answers
SOURCE: Lamp Cover will not close fully
Hi there
Your lamp is not properly inserted.
The lamp door should close easily if your lamp is in correct.
If teh lamp door is not closed properly then the mashine will keep on shutting down.
Posted on Apr 02, 2008
rockitman187
  • 2559 Answers
SOURCE: Please replace the lamp
On your remote,push these 4 buttons in this order.
RESET < > ENTER
Posted on Jan 12, 2009
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
  • 1614 Answers
SOURCE: someone from my work has
you shouldnt need a dvd to install the projector all you need to do is enable the external monitor interface on your laptop. User manual can be found here
http://www.aboutprojectors.com/pdf/sony-vpl-cs7-manual.pdf
Posted on May 30, 2011
My sony VPL-CS7 projector lamp goes of very minutes
1,if the lamp can be lit for 1minute,so the lamp is ok
it seems that the lamp ballast or mother board is defective.pls check them
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 03, 2014 | Sony VPL-CS7 Multimedia Projector
Can only view image in a very dark room.
If you need it you can get the user manual on this link; http://esupport.sony.com/perl/model-documents.pl?mdl=VPLCS7 check page 29 - brightness setting adjustment just to be sure this is not the problem. check page 36 - lamp mode - try high if not already set on it. Check page 42 - cleaning the filter - this can stop the projector functioning properly, but i don't think it's the problem in this case If the image is being projected exactly as normal, apart from the brightness, then the problem is most likely a failing bulb, despite the low hour count. Just possibly (but unlikely)there is a power supply problem that is not feeding enough voltage to the lamp, only way to tell for sure would be to either get a meter on the lamp terminals, which looks practically impossible with the lamp in place, (possibly will give a reading without the lamp, but the terminals may be disconnected from the power when the lamp is removed), or replace the lamp. Are there any flashing lights or error messages at all, does the projector seem hotter than usual, is the fan running as normal? could you actually see any error messages on the projected image if they were there? try really hard to read them if you think there could be something there. Try a different input source, unlikely problem but possible. Especially in smoky environments the lens can get quite a thick layer of grime on the outside - easily cleaned off gently with some vinegar and soft paper towel/soft cloth. This made enough difference on a similar one in a bar near me to give them 3 months more with the same bulb. Worth a try. If you need to source a bulb you need Sony LMP-E180 there appear to be no cheaper substitutes, you can get one direct from sony uk on this link; http://www.sony.co.uk/view/ShowArticle.action?articlesection=1&article=1158155174490&site=odw_en_GB These lamps are often cheaper from the US even with postage, if you can find a dealer who will send you one, check this link for some ideas; http://www1.epinions.com/t-sony-lmpe180 I got a lamp for a similar sony projector sent to spain a few months ago, saving about $280!!! - I'll keep trying to find the details of the company I used, no luck at the minute. Hope this helps, post back if you have any more info :)
Jun 30, 2007 | Sony VPL-CS7 VPL-CS7 MMPROJ XGA 1800LUMEN...
SONY VPL-CS7 LENS EMITS YELLOW RAYS HENCE NOT CLEAR
yo tengo el mismo problema alguien que tenga alguna solucion???
Feb 22, 2012 | Sony VPL-CS7 Multimedia Projector
Someone from my work has written instructions to connect the sony data projector vpl-cs7 to our laptop. it says to insert the dvd. I do not have the dvd so am keen to download it but i don't know what...
May 30, 2011 | Sony VPL-CS7 Multimedia Projector
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
How can we resate the lamp hurs
press key Reset,Right Arrow,Left Arrow then Enter and restart projector.Lamp hour show "0"
Feb 17, 2010 | Sony VPL-CS7 Multimedia Projector
Lamp/cover light flashes orange
could be need new lamp
very expensive!!
how old is the tv?
is this the first lamp?
usually get 10000 hours use out of one lamp
Jun 01, 2009 | Televison & Video
RESET < > ENTER
Jan 12, 2009 | Sony VPL-CS7 Multimedia Projector
Hi there
Dec 13, 2007 | Sony VPL-CS7 Multimedia Projector
Lamp/Cover Error
I had the same problem with a "Sony VPL-ES3" projector. The lamp cover light would flash and the projector wouldn't turn on.
I think its a problem with a filter cover. This fixed the problem for me:
  1. Plug out the projector
  2. Click off the filter at the bottom of the projector.
  3. Plug the projector back in. (the lamp cover light should flash)
  4. Plug the projector out again.
  5. Put the filter cover back on.
  6. Plug the projector in again and it should work fine.
This has worked for me every time I have had this problem.
Sep 29, 2007 | Sony VPL-ES3 Multimedia Projector
Sony VPL-CS7 Multimedia Projector Logo
323 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
