Question about HP Pavilion dv2120us Notebook
Ram capacity on HP Pavillion dv2120us
Hi-
I have an HP Pavillion dv2120us with a stated RAM limit of 2GB, however when I use the Windows help utility to check the installed hardware it says that I have 1GB installed (which is correct) and that the max RAM is 4GB. I've also read before that some dv2120us's while published to have a 2GB limit actually have a 4GB limit. Can I trust the windows help utility and buy 4GBs of ram to upgrade my laptop?
Just upgraded my dv2120us to 4GB RAM, 3.78 GB shows
Yes, trust the windows help utility and buy 4GB
Posted on May 24, 2010
    Master:
  • 538 Answers
Nope....that 2 gig is true..and the reason it may be invisible is that it is not seated properly, or, it is mismatched..
Posted on Oct 16, 2008
Requirements for building up a pentium 2
I'm not sure what you want to do, but you will find that you are going to be severely limited in what you can upgrade on the mainboard. This is because the mainboard was built specifically for HP/Compaq and as such the BIOS is not as generic as with an brand name mainboard that you can buy. Thus, you will find that you may have fewer CPU and RAM upgrade options. There is a good chance that you can probably expand the RAM capacity above 2GB. Remember though, that if you are only running a 32-bit Operating System, you will be limited to 3GB of accessible RAM regardless of the amount installed. Realistically, you probably won't be very happy with whatever performance gain(s) you can get for the money you will spend on this machine.
That said, most newer HP/Compaq desktops utilize a fairly standard ATX case. This allows you the possibility to install a completely new mainboard/CPU/RAM to gain massive performace benefits for the money spent. You may even be able to continue to use the existing hard drive and CD/DVD drive if they are SATA rather than PATA interface.
Mar 06, 2015 | HP Compaq Presario SR5350F Desktop PC...
Trying to help a buddy upgrade his gateway esx 500s memory as he only has 256mb, is there a limit to how much mem this comp can take or can i install 2GB 2x1GB PC2100 ECC REG MEMORY (CM12872ERX22100DI
Hi Steve Handel II,
Yes that machine has limited RAM capacity, that model can go up to 1GB of RAM total (2x512MB DIMMs.) It takes DDR PC2700, CL=2.5 unbuffered, non-ECC DDR333 memory chips. The good news is you can get them for $10-$20 most anywhere. Like HERE
Good Luck
Mark
May 11, 2012 | Computers & Internet
How much ram can i upgrade my compaq presario? I keep getting conflicting info. The tech at Office Depot said I was maxed out 2Gigs and upgrading any more would shut it down. But I'm reading forums...
One good and easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
I hope that was helpful to you, good luck.
Joe.
Nov 05, 2011 | HP Compaq Presario SR5350F Desktop PC...
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
My direct3ddevice9 crashes when i load any 3d game.. i have windows vista home with 2gb ram 320gb hard disk
My direct3ddevice9 crashes when i load any 3d game.. i have windows vista ... Problem for HP Pavillion DV2815NR (KN998UAABA) PC Notebook ... i load any 3d game.. i have windows vista home with 2gb ram 320gb hard disk ...
www.fixya.com/support/t5320207-direct3ddevice9_crashes
Jul 16, 2010 | HP Pavillion DV2815NR Notebook
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
Jan 05, 2010 | HP Pavilion dv1000 Notebook
HP Pavillion a805n won't power up
what is your household Current? that voltage setting will not work in the United States since household current is 120. The switch in the US should be set for 120 volts AC. If you out the old ram back in place will the computer power up? If yes then you may have exceeded the capacity of the computer. You also need to check the the BIOS settings to make sure that the computer detected the new ram.
Aug 24, 2009 | HP Pavilion a805n (PS519AA) PC Desktop
To upgrade power ram 2gb to my compaq presario f700 laptop,please help.thank.
Hi there. According to the specifications website on HP.com, this system originally shipped with 2GB of RAM, and only supports a maximum of 2GB. There may be a chance that the mainboard can support 3 or even 4GB of RAM, but it has not been tested thoroughly, and it is not guaranteed to work if you do go above and beyond the maximum supported specifications.
Jun 12, 2009 | Computers & Internet
Computers & Internet Logo
307 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
