Question about HP LaserJet 2300 Printer
Horizontal Lines Every page that prints has horizontal lines starting about 1/2 inch from the top and continuing down the page (getting darker as it goes) every 1.5 inches. HELP!
    Problem Solver:
  • 10 Answers
Try another toner and see if it changes. if it does not then you may need a fuser,
Posted on Oct 16, 2008
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the seco
Is it prints or copies or both? If it's copies, clean the document feeder glass - small strip. What make/model? Laser? If laser, check the fuser roller
Nov 29, 2014 | Office Equipment & Supplies
Why are there Horizontal lines on copies spaced every 3 inches apar?
Download the following manual and check pages 1-293 through 1-308. The main problems with line on the page are do to (1) bad toner cartridge, (2) bad transfer belt and (3) bad fuser. If you want a more detailed explanation on how to get ride of lines let me know.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%203130cn%20Full%20Manual.pdf
Aug 13, 2014 | Dell 3130cn Color Laser Printer
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
Horizontal lines appear every 4 inches on each
User manual page 6.17 says:
Horizontal streaks indicate improperly installed or defective toner cartridge. Try re-installing the cartridge.
http://downloadcenter.samsung.com/content/UM/200607/20060712143739406_ML-1710_English.pdf
Nov 28, 2009 | Samsung ML 1710 Laser Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Dell Print Quality Problems: Horizontal lines On One Side
Try running a cleaning sheet through the printer. Remove the drum and check you waste toner (if that is built-in to your drum then skip this). If that gets full, then some of the bad toner can spill out creating lines/smuges. I would also use compressed air to blow out the inside of the printer where the toner/drum goes. That will help remove anything that is left behind after a replacement.
Also, check the settings in the print server for anything that will clean the printer/correct horizontal lines.
Mar 16, 2009 | Dell 3010cn Laser Printer
Horizontal lines on printed page
You need a new Toner Cartridge
Feb 01, 2009 | HP LaserJet 1300 Printer
Horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Sep 11, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2300 Printer Logo
496 people viewed this question
Seeker5211
Seeker5211
