Question about Cnet CWR-854 Router
Cnet CWR 854 Router
I properly connected the router but unable to connect to the internet. When typing the IP 192.168.1254 it tells me that the computer can not connect to the internet. WLAN  / WAN  lights are not lit, I have reset the router, but all unsuccessful. Any suggestions other than changing the router for a new one, done that already with no success? Thanks
  • Cnet Master
  • 6,487 Answers
Try this another way of resetting the router, Press and hold teh reset button for 30 seconds while the power is ON then after 0 seconds unplug the power of the router for 10 seconds , then check again if the lights WAN and WLAN lights are still OFF, if its still OFF you can try calling this number for further assistance for this router 1-877-787-8749 so atechnician can walk you through in checking if this router si really bad already or still can be fix....
Posted on Oct 16, 2008
2 Suggested Answers
SOURCE: How to use my Cnet CWR-854 Router as a wirerless antenna for pc.
You can't really use a router to connect to another router, you can sometimes use them as an "Extender" for range, but not as a WiFi card, they simply aren't made to operate that way.
Posted on Feb 19, 2010
What is it used for?
You can use this wireless router to connect different wireless devices together. Each device with a wireless network card (computer, phone, gaming system, printer, etc.) can connect to the router without a cable. This will form a network where information can be shared.
The main purpose people use this for is to connect their network to the internet. As long as the router is connected to your internet, every other wireless device can also connect.
Thanks,
Pat
May 24, 2010 | Cnet CWR-854 Router
Cannot connect to internet, already configure my wireless CWR-854, thru 192.168.1.254, when im in internet, my deafault gateway is 192.168.1.1, please help
online user manual is here http://www.cnet.com.tw/download/cwr-854.htm If you goto page 37 it show the dhcp range . Make sure your pc cofiguration is set to dhcp - automatically obtain and IP and DNS - this is explained on page 10/11 try this Start>run{vista/7 search box}>cmd>ipconfig /release Start>run{vista/7 search box}>cmd>ipconfig /renew see if that produces the correct info
Mar 20, 2010 | Cnet CWR-854 Router
Feb 19, 2010 | Computers & Internet
Trying to access 192.168.1.254 for siemens se567, followed advice to go to run and cmd ping, don't understand other go to access point, my situation is the older couple I live with have wirless internet in...
The internet connection has a security that's why you can't access the internet. The only thing you have to do is to know the wpa password of the router.
This router has a default username and password to configure all the settings. This is the manual for Cnet CWR-854 Router:
http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20User%20Guide.pdf
It seems that the router is already configured by an authorized person, the best thing you should do is contact the authorized person that knows everything about the router.
Jan 25, 2010 | Cnet CWR-854 Router
Cannot connect to 192.168.1.254
why would you want to do that? ;O)
need more information
If you are trying to set up the router for the first time ensure you are using a cable not wireless connection. With wire connected can you get the set up screen on that ip? if not open a dos window (start>all program>accessories>command prompt) and type ipconfig and it will tell you the ip the router is using. try using that ip instead
Dec 29, 2009 | Cnet CWR-854 Router
Is there a conflict between linksys BEFW11S4 router and CWR-854 cnet router?
No problem at all. The router can function as bridge with no conflicts with other routers.
Nov 10, 2008 | Cnet CWR-854 Router
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
No access to web based utilty
Seems like you need to verify that the web management interface is at the address your specified or that your PC is indeed wirelessly connected to the CWR-854.
The following suggestions assume you use Windows XP as your OS:
  1. You need to connect to the CWR-854 via a network cable (one end connected to your PC the other to a LAN port on the CWR-854) initially.
  2. You can try to access the web management interface at the IP address you expect, i.e. 192.168.1.1 or you can verify the IP address by finding the Default Gateway your PC is issued by the CWR-854 from:
  • Right clicking on the tray icon of the network connection, choose "Status" then click on the "Support" tab to see the Default Gateway.
  • OR click on "Start" then "Run...", type "cmd" then type "ipconfig" and read the Default Gateway value under the section for the "Ethernet adapter Local Area Connection".
Use the Default Gateway value as the new address to use for the web based utility if it differs from what you expected.
Jul 26, 2008 | Cnet CWR-854 Router
CWR-854 router
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Jan 18, 2008 | Cnet CWR-854 Router
Setting up a wireless network with internet
You will need to logon the router via the computer, and create a PPPOE internet connection. If you cannot connect to the router wirelessly my may need to use a cat5 cable between the computer and the router. The user manual that came with the router will show you how to do this. If you do not have the manual. Do the following: open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway".once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank.once logged on the router go to internet connections and select PPPOE enter the username and password provided by your ISP save the settings and you should make the internet connection now. BPCS
Dec 26, 2007 | Cnet CWR-854 Router
Cnet CWR-854 Router Logo
271 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
