Vcr timer does not work
Hello i have just bought a digilogic vcr/dvd combi model no dvdvcr2.
i have tuned in the channels and set the recording timer. the programme timer is stored , the clock is correct but the tape doesnt start to record. why??
G. COLLINS
5 Suggested Answers
ANTHONYPAULB
  • 17 Answers
SOURCE: Funi vcr combi
theres probably something out of whack in the vcr probably one of the pins inside your best best if you want to keep it is to take it to a repair shop or if your handy open it up and see if anything is either stuck in there or bent.
Posted on Nov 30, 2007
robotek
  • 1512 Answers
SOURCE: recording problem onkya model ta2090
check electrolytic caps about the dolby chip. have seen caps (maybe 100uf) go dry and produce problems like this
Posted on Dec 09, 2007
  • 579 Answers
SOURCE: sharp dv-rw260h vcr/dvd combi
The tape drive and head cylinder motors are having trouble synchronizing close enough to allow the manual tracking to work. Does it work on prerecorded tapes?
Could be:
Too much drag from the tensioning gizmo. (fixable)
Dirty tape path (fixable)
Damaged tape (does it have a crease along one edge?
dragging motor (not usually fixable)
Hope Ya Fix It!
Posted on Jan 18, 2008
  • 275 Answers
SOURCE: VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Posted on Dec 02, 2008
  • 4 Answers
SOURCE: Sharp VCR hooked up to cable tv, i/p to vcr then out to tv.
I believe that I have the solution to that problem... When you are hooked up to cable or dish and use a VCR, you MUST have the program you wish to tape playing on the Cable or dish program, therefore the VCR needs to be tuned to channel 3 or 4 {whichever is the unused channel in your area) I believe that all you have to do is make sure that the TV is tuned to the channel you wish to tape and program the VCR to Channel 3 (at my area) or channel 4.
I hope this works for you. I have VCRs hooked up to all my sets and this is how mine work.
annabanana
Posted on Jan 25, 2009
Digilogic dvdvcr2 have no manual or remote how do i copy from vcr to dvd?
I have one of these, just purchased. The manual does not cover Recordings VHS to DVD only the reverse DVD to VHS. I do not think you can record onto DVDs from VCRs
Jul 16, 2010 | Televison & Video
Tip
Digilogic DVDVCR2 Safe Mode Unlock
Digilogic DVDVCR2 Unlock Safe Mode
Is your Digilogic DVDVCR2 stuck in SAFE mode?
Is is locked and unresponsive?
To unlock your Digilogic DVDVCR2, simply press and hold the red power button on the remote for at least five seconds. Sometimes it takes longer, so you may have to hold it up to 30 seconds to make your player usable again.
I hope that helps.
__________________________________
Would you like to unlock your Digilogic DVDVCR2 in another way?
Read my other Digilogic tip to make it a region free / multiregion dvd player.
on Apr 07, 2010 | Televison & Video
Tip
Digilogic DVDVCR2 Region Free Code Would you like your Digilogic DVDVCR2 to be...
Would you like your Digilogic DVDVCR2 to be region-free and play all DVDs? Here are the steps to make your Digilogic DVDVCR2 region free:
  1. Press the Standby button on your remote control to place the unit into Standby
  2. Press the Standby button on your remote control to turn on the unit
  3. Press the Open/Close button on your remote control to open the drive tray
  4. Press the Clear button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 3 button on your remote control
  7. Press the 6 button on your remote control
  8. Press the 9 button on your remote control
  9. Press the 0 button on your remote control
  10. Press the Open/Close button on your remote control to close the drive tray
  11. Press the Standby button on your remote control to place the unit into Standby
  12. Press the Standby button on your remote control to turn on the unit
Your DVD / VCR combo is now region free.
Is your Digilogic DVDVCR2 locked in SAFE mode? View my other Digilogic tip to unlock SAFE mode.
I need a manual for a Digilogic DVDVCR2
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The above link will direct you to the manual.Please do rate if we could solve your problem.Thank you.
Sep 07, 2008 | Califone International DVDVCR200 DVD...
The dvD PLAYER ON MY dIGILOGIC VCR/DVD COMBIE wOULD NOT PLAY ANY DVDS NEW OR OLD tHE VERSION IS DVDVCR2
I can help you unlock the region free feature of your digilogic dvdvcr2, and I can also fix it if it is locked in safe mode.
I hope either of those solves your problem.
Aug 18, 2008 | Televison & Video
Multi-region don't know how to start it
the company said it was multi regional compatible and lied it was not be careful of these promises as you could loose out like me
Jul 05, 2008 | Califone International DVDVCR200 DVD...
The model I having problem with is DVDVCR2
I can help with at least two Digilogic DVDVCR2 problems:
I can make them region free,
and I can unlock them from SAFE mode.
I hope that helps.
Jan 08, 2008 | Califone International DVDVCR200 DVD...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
