Question about Maytag EPIC MFW9700S Front Load Washer
Reset childlock model mah2400aww
I set the childlock on my washing machine and one of the buttons broke off so i cant disable the childlock and i cant use the machine is there a way to reset the machine or disable the childlock using another button?
  • Anonymous Nov 16, 2008
    my door is syuck on door lock
  • Bettyblue Apr 21, 2009
    I have a samsung Q1435v BigWash and it's been working fine for the last 4 years until today my power went off while it was in pause mode and now the child lock is stuck on and won't release. I drained the water out manually and opened the door using the emergency door release so I could get clothes out, but now can't press any buttons at all as the lock remains on.
I just got a maytag epic z washer and dryer the epic washer door locks and when i stopped it the door wont rest and open what do i do to re set it?
Posted on Feb 12, 2009
  • cottoncan379 Feb 12, 2009
    its unplugged now i hope that works i just got them today :(
  • 523 Answers
Did you try to unplug the unit for 30 minutes
Posted on Nov 09, 2008
How do I change the language on my new Hotpoint TCUD93BG, I pressed it by accident and its now unreadable, I tryed to reset it by holding 3 buttons but it doesnt work
Turn on the machine with the door open using the on/off button
Press and hold the childlock,temperature and spin buttons at the same time for approx 5 seconds. The sceen will flash.
Scrollup/down using the temperature or spin buttons until the required language is seen in the display.
Press the child lock button to save the new setting.
Dec 04, 2012 | Washing Machines
Childlock flashing unable start machine
Hi there, without some details of the make and model of your machine I can't tell you what buttons to press to perform a reset of the machine, however, this is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up. Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Aug 08, 2011 | Washing Machines
I have a double draw dishwasher . the child lock key comes up and the dishwasher does not start
The lock button activates/deactivates the Keylock or the Childlock functions. This button has either a key or a padlock icon. I believe that on this model it is a padlock
Keylock
The Keylock feature disables all the buttons on the control panel.
To activate, press and hold the button until you hear one beep (3 seconds). The symbol
appears in the electronic display when the Keylock feature is activated.
Childlock
The Childlock feature locks the drawer and disables all the buttons on the control panel.
To activate, press and hold the button until you hear two beeps (5 seconds). The symbol
appears in the electronic display when the Childlock feature is activated.
To cancel the Childlock feature, press and hold the button until you hear one beep and the
symbol disappears from the electronic display.
This information can also be found in your product's Use and Care manual. If yours has been misplaced you can download or print one from Fisher and Paykel's website. http://www.fisherpaykel.com/customercare/userguide/index.cfm
If this doesn't work... And I've seen these units do some odd things. Try unplugging it for about an hour (if plug is not under sink you can turn of the breaker that powers the unit). Then plug it back in and see if that works. These dishwasher like many modern day appliances have solid state microprocessors in them which sometimes need reset just like a computer.
Hope this helps.
May 17, 2011 | Fisher and Paykel 23 in. DD603H SS...
The Maytag repairman says my model number is MAH2400AWW. You tell me: No manuals found for mah2400aww manuals. What now?
Check for yourself, pull the washer out, and check the back. model numbers/serial numbers are normally tagged on the back.
Dec 31, 2009 | Maytag MAH2400A Front Load Washer
How do we get childlock off a hotpoint wm 864
When activated all the buttons will be disabled and a child will not be able to alter any wash programme or option settings. Once selected this feature remains activated, even when the machine is ‘off’.
To use this feature press the ‘Child Lock’ button and hold down for 2 seconds. The child safe icon will begin to flash. When the icon stops flashing the feature is activated. If any of the control buttons are pressed, the child safe icon will flash and the machine will bleep 3 times: no alterations to the control settings will be allowed. If power is interrupted, at any time, pressing any button will reactivate the child lock feature.
To deactivate this feature hold the ‘Child Lock’ button down for 4 seconds. You will then hear a bleep and the child safe icon will go out.
Oct 25, 2009 | Washing Machines
I can't remove the childlock on my washing machine! Can you help?
Sep 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
CHILD LOCK STUCK ON
I agree with the initial solution, depress the child lock button for at least 3 seconds.
If it does not clear, then try again.
Good luck.
Please rate my solution.
Thanks.
Feb 12, 2009 | Hotpoint WMA74 Front Load Washer
Childlock on tv without remote
unplug it for and hour or two and plug it back in
usually this will reset the tv's settings and the child lock will be turned off.
Oct 22, 2008 | Televison & Video
Maytag EPIC MFW9700S Front Load Washer Logo
965 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
