Question about Sharp AL-1642CS Copier
The copier is not funcioning.
L and 1. What should i do to restore it?
  • ESP597 Oct 16, 2008
    I solved it already from the viewed solutions.
    Problem Solver:
  • 12 Answers
Hi ESP597,
We haven't had this particular model in South Africa but the "L1" error code on a SHARP machine normally means that there is a problem with the scanning unit (where the exposure lamp is under the glass) on the top of the machine.
The unit does not return fully to the "home" position within the required time interval.
Various things could cause this.
The most common one is that there is an obstruction of some kind preventing the unit from reaching the right position.
Some models have a clear plastic transport stopper that sometimes gets turned by accident when the user tries to clean the machine. If your model has such a stopper to locate it look in the cavity where the paper comes out of the machine,towards the left front of the upper part of the machine the stopper is normally sircular in shape and rotates through 90 to 180 degrees.(its function is to lock the scanner unit during transportation so as to protect the lamp from damage)
If your model has this stopper then rotate it in the opposit direction to where it currently is and the problem should be solved.
If however there is no stopper then there is very little that you can do yourself other than to contact the closest SHARP service centre for assistance.
Hope this has been of assistance to you
Regards
Gavin
Posted on Oct 18, 2008
Apear star in A4 tray
user funcion-user-drawer
disable all these options
thichi-insert-cover-special
Dec 07, 2013 | Toshiba estudio 305 Copier
Como hago que funciones el asistente y el scaner de la impresora lexmark x2250
La guía para el X2250 de Lexmark usuario de la impresora le puede dar instrucciones más detalladas sobre cómo utilizar las características de la impresora y funciones.Puede descargar la guía del usuario del sitio web de Lexmark en http://bit.ly/mEpFyZ.
Nota: Esto se traduce con translate.google.com.
May 10, 2011 | Lexmark X2250 All-In-One InkJet Printer
My is canon ir 3570 and it show errow E0000_0001 what can i do to clear the code im trying to enter *28# but it is not responding what can i do?
press additional function>2,8> additional funcion
click copier, click function> CLEAR>ERR>OK
switch off wait for 15 minutes and then switch on.
Apr 14, 2011 | Office Equipment & Supplies
Tengo una asus y no puedo escribir la letra enie.
para que pueda meter caracteres con la combinacion alt - (numero) tiene que utilizar el key pad numerico,
en un laptop para poder utilizar el keypad numerico (letras: u, i, o ; j, k, l; m, <, >) necesita utilizar la tecla "fn" y la tecla funcion que activa el key pad numerico (en mi caso es la tecla f11), en su caso puede ser diferente, mire los symbolos en las teclas de funcion, hay un simbolo que asemeja en teclado numerico diminuto.
por ejemplo para meter la letra "ñ" presione lo sigue
1. active el keypad numerico tecleando una vez y simultaneamente "fn" y f11 (o la tecla que active esta funcion en su teclado).
2. ahora si teclee alt y manteniendo presionado alt, teclee uno a uno las teclas j, o, u las cuales ya deben estar activas como numeros 1, 6, 4 respectivamente.
Apr 11, 2010 | ASUS Eee PC 900 Notebook
All funcions freeze.have to switch off and start again .crash's screen goes blank' it is only four monts old
Try to start the compute in safe mode, and check if the computer works without any issue, to access safemode, you have to press the F8 key while you get the Acer Logo.
Try restoring the Operating system by pressing Alt+F10 when you get the Acer logo and follow the screen.
Apr 07, 2010 | Acer Aspire One PC Notebook
Funcional problem code SC542
Hello sir; Follow the steps to reset;
1, press "clear mode", "107", then press and hold "clear/stop" key untill display change.
2, enter 5810, then press "execute" on screen, then press "close".
3, turn power off then back on, it will go back to normal.
Apr 28, 2009 | Ricoh Aficio 1018D Copier
How to print envelopes on clc 5000
this not necessary a software because this machine have got that funcion on setting to bypass and casset
Feb 10, 2009 | Canon CLC 5000 Copier
Canon BJC ink jet printer
May we know what are the things you've tried?
Jul 26, 2008 | Canon BJC 2100 InkJet Printer
93 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
