Question about Bruder Cat Skid Steer Loader
Bobcat skid loader model 863
How do i replace the fuel line that goes into the tank in a 863 Bobcat skid loader
4 Suggested Answers
SOURCE: what do you have to remove to get to the fuel tank
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Posted on Oct 05, 2009
  • 223 Answers
SOURCE: I have an 863 bobcat that doesn't idle well and
There should be more than just one filter on that motor, check at the lift pump and injector pump.
Gelled fuel can be a pain, if that's the problem then warm it up (tarp and salamander for a few hours or leave it inside the shop overnight if the shop is warm), top off the fuel and give it a can of Power Service brand Diesel Kleen, then try it.
lp
Posted on Dec 30, 2010
SOURCE: I have a bobcat 863,
the fuel intake is from the top of the fuel tank, there is a tube which goes to the bottom of the tank. This tube may have deteriorated and come off or have a crack. You can lift the cab and reach down to the tank to pull the plug to check. good luck
Posted on Feb 06, 2011
SOURCE: i need a parts diagram for a 743 bobcat steer skid
i have a 743 bobcat the hydraulics are noisy and moves very irratic now like its not getting any fluid any ideas
Posted on Jun 20, 2011
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
Need repair manual for bobcat 753 Skid Steer Loader
google it perhaps they know where you can buy one
May 11, 2015 | Toys
How do I remove the slide arm on my 643 bobcat
Bobcat 641 642 643 Skid Steer Loader Workshop Service Repair Manua dowload
This is the most practical Service Repair Manual for the Bobcat 641 642 643 Skid Steer Loader Workshop Service Repair Manual Download ever compiled by mankind. This DOWNLOAD contains of high quality diagrams and instructions on how to service and repair your Bobcat 641 642 643 ,you can download it.This is a must for the Do-It-Yourselfer!
Jul 30, 2013 | Computers & Internet
863 bobcat getting oil in fuel
Internal leak in lift pump. Leaks fuel into cam to oil pan.
Jun 21, 2012 | Bruder Cat Skid Steer Loader
I have a bobcat 863, turns over ok, but will not start. Did not run out of fuel.
Jan 27, 2011 | Bruder Cat Skid Steer Loader
I have an 863 bobcat that doesn't idle well and continues to quit running. I changed the fuel filter, put heat in tank and a little bit of diesel conditioner anti-gel.
lp
Dec 30, 2010 | Bruder Cat Skid Steer Loader
Replace fuel line on 863 bobcat
you need to take off thr right rear tire and remove inspection plate,then reach in and pull line from top of tank. if pickup tube is original eqip. it has probably broke off. you will find 3/4 of old tube in bottom of tank. go to bobcat dealer and get replacement tube,which is now all poly and flexible. while you are at it,reroute fuel line to the plunger,by putting it down bottom right side of engine,right under motor mount below alternator. an easy test of fuel line is to take off fuel cap and then blow air in hose at primer bulb towards tank.if you hear the air at fuel tank opening,your tube is broken. if you hear bubbling line should be good. you need to have a can of air in your tool kit,go to walmart and get can of air in the electronics department,the opening is small,get yourself an male air fitting from automotives and put on end of air can,use pipe tape on end. if fuel line gets dirty you can blow back to tank at primer bulb,this an emergency fix,if primer bulb is collapsed the line is clogged or pickup is clogged.
Jan 11, 2010 | Bruder Cat Skid Steer Loader
What do you have to remove to get to the fuel tank on 863 bobcat
Jun 25, 2009 | Bruder Cat Skid Steer Loader
Bruder Cat Skid Steer Loader Logo
288 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
Iron
Iron
ptpumpman
Are you a Bruder Toy Expert? Answer questions, earn points and help others
