Question about AT&T 650530003417 Cordless Phone
My AT&T handset has no dial tone
I was having some problems with my caller id so I took the battery out of my phone and replaced it to see if that would fix the issue. After putting the battery back in I realized that there was no dial tone. Every time I hit the little green phone button to make a call, the screen read other handset on or out of range! Please Help!!!
  • 1 more comment
  • trtyler Nov 07, 2008
    My ATT Phone Model E5828B has the same problem: When I push the "phone button" the message "connecting" comes on the screen for about 10 seconds then there are 5ive quick tones and the message "Other Handset On Or Out Of Range". I've tried all 7 of the tips provided on the ATT web site and none corrects this problem. Unfortunately I had the phones in a condo at the beach for about 6 months without use and the problem developed when I tried to use the phones on vacation; their out of warrantee now. Any suggestions?
  • Anonymous Jan 08, 2009
    Same problem.
  • Anonymous Apr 28, 2009
    I have the same problem. I only had the phone 1 week at our condo, came back to use it and neither remote phone would work: "Other phone in use or out of range". Went through all the trouble shooting suggestions none of which solved the problem. Bought a new battery; still did not solve the problem. In my opinion they're just crumy phones! I'll never buy ATT agian!
silly girl
  • 513 Answers
SOURCE: "searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Posted on Jun 05, 2006
  • 106 Answers
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website-
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Posted on Feb 18, 2008
  • 14 Answers
SOURCE: Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Posted on Apr 01, 2008
SOURCE: There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone?
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Posted on Aug 05, 2008
SOURCE: Will not call out!!! 25204RE1
I just encountered this same problem on my phone. To resolve, you must hard reset the phone as follows: unplug power cord, unplug phone cord, remove all batteries. Leave disconnected in this state for at least 10 minutes. Now reconnect in following order: reinstalling batteries, reattach the phone cord followed by plugging in the power cord. This restores the phone to the original settings. You will lose items in memory, but the phone dial function should be restored. This was recommended by customer service and resolved my issue which sounds identical to yours. You can now proceed with resetting up your phone as desired.
Posted on Feb 12, 2009
Can not get a dial tone
If you cannot get a dial tone, the problem may be outside.
Sep 09, 2014 | Vtech CareLine SN6197 Standard Phone -...
No Dial Tone from BT Diverse 7110 Single
Check that the volume on the handset is turned up, also replace the batteries or put in non-rechargeable ones to get the phone working at full capacity. If bought from Amazon you should be guaranteed for a year, not a month!
Mar 03, 2014 | BT Diverse 7110 Plus Cordless Phone - DECT...
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Phone Rings,but cannot answer
if there is no dial tone that means that the connection is not being made when you pick up the phone hence you cannot answer nor can you get a dial tone
the fact that the phone rings indicates that the land line is good so the fault is in the phone itself
Nov 06, 2017 | Panasonic KX-TG5652 Twin Cordless Phone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
GE28112 Dect phone
Here are the instructions and a link to the manual :
Key Tone
From the Handset Setup Menu:
1. Press the caller ID-volume ( 6 or 5) button to scroll to the KEY TONE sub-menu.
2. Press mute/program button to enter the menu. SET KEY TONE 41ON 2 OFF shows in the display. The default setting is 1ON.
3. Use the touch tone pad on the handset to select 1 or 2, or use the caller ID-volume ( 6 or 5) button to scroll to your selection.
Here is a link to the manual for you :
Jan 05, 2008 | GE 28111 Cordless Phone
AT&T 650530003417 Cordless Phone Logo
366 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
