Question about Saitek Cyborg Rumble Pad Game Pad
Setting up rumble pad
I am 46 years old. I want to set up my controller without all the tecnical
information that the manual explains. I do not understand the manual, nor
what to do.
I have pc games that I want to play because I am used to a controller and not the keys. Though I am told that once I switch to FPS on the rumble pad that I am able to play without the setup, this I find to not be true. I want to play Call of Duty.
Please help this young man at heart.
Ok well here is what i did for using the direction pad to play flatout, a pc racing game, using the Wireless rumblepad 2 controller. First open up profiler, click on d-pad, select assignment, then click new POV assignment. Put a check on FPS style movement. Then click edit, then click new keystroke. Hit record and then on the keyboard hit the up, down, left and right keys. Then hit stop and click ok. click cancel on the window right behind it. So now you are viewing the POV assignment window that we opened before. Here what you do is, say for instance hit the "N" button and then to the right of it you see "pov north", hit the scroll down menu and hit "keystroke Up" for N. Like wise you click the "E" button and for POV east you assign "Keystroke right". And so like wise "keystroke down" for "S" and "keystroke left" for "W". Once you have all that done. You hit ok and just open up whatever game you want to play and the Direction pad should be able to allow you to steer or go in the up, down, left or right direction. Hope these instructions help solve your problem.
Posted on Nov 02, 2008
  • xgames Nov 02, 2008
    sorry one correction. Before you even assign d pad setting as i have explained, you have to have the actual game in the logitec profiler window set. So if you want to play call of duty have that one in the profiler and then start setting up the d-pad.
Why has my heated mattress pad stopped working?
Electronics fail. Sounds like the digital controller has failed. A Google search finds others with the same problem. Biddeford models come with a 5-year warranty, so if yours is less than 5 years old, I suggest you contact Biddeford by telephone: 800.789.6441 or visit their website: http://www.biddefordblankets.com/warranty.asp
Sep 15, 2014 | Biddeford Blankets Heated Mattress Pad...
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
I just purchased dreamgear wireless rumble pad. It tells me to insert a USB into the front of my game set wear I would connect a contoller with a wire attached to it. What is the USB it is refering to and...
IT IS CALLED MINI B USB CABLE
YOU CAN FIND IT AT BEST BUY, RADIOSHACK AND ALMOST EVERY ELECTRONIC SHOP
http://www.sears.com/shc/s/p_10153_12605_SPM498602701P?sid=IDx20101019x00001a&ci_src=14110944&ci_sku=SPM498602701
RATE IF THIS SOLVED YOUR PROBLEM
Apr 11, 2011 | DreamGear DGPS3-1346 Lava Glow Wireless...
My Cyborg Rumble gamepad is always going at the upper left. It is stuck there. What can I do?
technical solution:
try another PC - if this Pad make the same problems this another System -> back to the Store.
Feb 22, 2011 | Saitek Cyborg Rumble Pad Game Pad
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Hi my name is jatt and i don't know how profile saitek cyborg pc
Hi there, go into control panel. When in control panel, click switch to classic view. Then click on game controllers and you will have settings for your game controller.
Jan 18, 2010 | Saitek Cyborg Rumble Pad Game Pad
Model g22012
If its the digital display with I think 2 or 3 buttons, then you cannot re-program the control.
It is factory set and I have never been able to get any clear answers from Traulsen on the steps to re-programming it for a different setting.
Best advice I can give you is to contact Traulsen directly and ask for tech support. Once you get them on the phone, explain that you just purchased this cooler/freezer and you need a control that suites your needs. They should have one that is pre-programmed to your needs.
Jan 07, 2010 | Traulsen 46 cu. ft. Upright Freezer G22011
Bad idle on 2002 Saturn Vue
make sure you have no hoses on the engine that fell off listen for a hissing at idle. If all ok and you checked for codes which should be done before any parts are replaced then the most likely cause is the Idle Air Control Valve. (IAC). IAC's usually wont set a code.
Sep 28, 2009 | 2002 Saturn VUE
F stop on a Canon EOS 50
The EOS 50 is the same as the EOS Elan II, and you can download the manual here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=313&modelid=8196
Page 54 explains setting aperture in Av mode, and page 56 explains setting aperture in the Manual mode.
Dec 31, 2007 | Canon EOS-50E 35mm SLR Camera
Saitek Cyborg Rumble Pad Game Pad Logo
962 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Rob Emerson
Rob Emerson
juanmireles1
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
