I have a Philips dvdr5520h/05 which I would like to make region free. I have tried the following which does not work: (1)No disk in tray. - Tray closed. Press: [HDD LIST] (donĀ“t select a file) Press: [Play] Press: 159 12 12 12 005 255 (numbers appear in the display) Press: [Play] (unfortunaly a file is always selected) (2) Go into the main menu Highlight the exit button Type 2960 This should give you access to a hidden menu form where you can change the region code (No exit button to highlight, all menu say press HOME to exit) Thanks Bob
  • smg5 Oct 18, 2008
    Is the [Play]the same as the OK? or are you refereing to the play/pause button?
    regards
    SMG
Try all the above but wheh u tpye in the 159 121212 005 255 then tpye the 2960 on to it then press the play button then press home to exit
Posted on Nov 06, 2008
Would like unlock code for Philips HTS5593 Blu ray
To make your Philips BDP3100 region free (this works on a BDP3100/05 purchesed in the UK in June2010)
1. Make sure there is no disc in the tray when you switch on.
2. Press "home" key on remote control.
3. Enter number "1389310".
4. Switch off. Wait a few seconds and then switch on...now region free.
Please note, the above hack has only been confirmed as providing region-free DVD, not Blu-Ray.
Mar 14, 2013 | Philips HTS5593/12 3D Home cinema system...
Srtill no luck with help to unlock my philips dvd player to be region free
Please try the following procedure: start the player without any disk on it, open the disk tray, leave this way and at your remote control press 9 9 9 9 0 , you should see region 0 displayed, then close the disk tray, your player should be now region free.
Feb 18, 2011 | Philips DVP320 DVD Player
My philips dvd hts 3545 does not play the dvd says there is no disk. it could be a problem of region code. how can i unlock the region code to make all region code
hi,
you can make the player region free by the following setup.
1.TURN ON THE PLAYER
2.PRESS OPEN/CLOSE TO OPEN THE TRAY
3.WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6 in sequence
4.YOUR REGION AREA WILL BE DISPLAYED.
5.PRESS "0" TO UNLOCK ALL
6.PRESS "OK"
ok
Jan 26, 2011 | Philips Televison & Video
How can i change the region on my Philips DVP630 Help please
Turn On Player
Open Disk Tray (From Front Panel)
Using Remote Control Press 7 8 9 OK 0 (Zero)
( Number Will Appear On Screen Denoting Region)
Close Disk Tray
Player is Now Region Free
hope this helps
John
Jan 22, 2011 | Philips DVP630 DVD Player
I need to reset the region code on a samsung home cinema system HT-X200
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray. 1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM) 2. Reconnect to mains 3. Turn on player with remote. 4. Press ENTER on remote. 5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2 6. Press ENTER on remote. (The tray will open and player will power off and close tray.) 7. Switch on power from remote. 8. Player is now Region Free. Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | Samsung Audio Players & Recorders
Want to play my old DVDs from overseas, but I get a region code error.
Try the following:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
7. Press 8, 4, 2, 6, 9. Using keys on remote. If your player is already set to region 2
8. Press ENTER on remote. (The tray will open and player will power off and close tray.)
9. Switch on power from remote.
Apr 16, 2009 | Samsung HT-DS610 System
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
Wrong region
hi!your english is good!!
please try this:hope it helps!
dvp720sa
dvd player on
open tray
(no disk inside)
1. Turn on the player.
2. Open the tray.
3. Press the following sequence on the remote: 9-9-9-9-0
4. The number 0 will appear on the lower left side of your screen.
5. Your player is now region free! Put in a DVD and enjoy!
NOTE: The 0 in the sequence above represents the region code. 0 = region free. If you want to change your player to just a specific region code, replace the 0 with the region number you want.
Nov 20, 2008 | Philips DVP 720SA DVD Player
PHILIPS DVDR5520H REGION UNLOCK CODE
- No disk in tray.
- Tray closed.
Press: [HDD LIST] (don´t select a file)
Press: [Play]
Press: [Play]
You get no feedback that it works, but test with any region now. The player is now region free.
Nov 01, 2008 | Philips DVDR520H DVD Player/HDD
How to make philips HTS3565 region free. Any help will be appreciated. Thanks.!
icon_minipost.gifRegion code hack posted by videohelp4k1ng, July 27 2008:
Hack for HTS3050 also worked with my HTS3565D.
Open the tray. Press 99990 on the remote.
Region 0 will appear briefly on the left of the screen.
icon_minipost.gifRegion code hack posted by rocky631689, August 01 2008:
Also works on my Philips HTS3568DW/75
THANK YOU!!!!!!!
icon_minipost.gifRegion code hack posted by mikoyan, August 05 2008:
I´ve just applied to my HTS3565D/37 and it worked great. Do not expect it to show anything in the display, though. You open the tray, click the sequence in the remote and... Done!
Sep 03, 2008 | Philips HTS3500S System
Televison & Video Logo
473 people viewed this question
Top Televison & Video Experts
Electro Med Services...
