Question about Minolta EP1083 CS/PRO Copier
PAPER FEED I AM HOPING I CAN DISCONNECT THE SORTER FROM THE COPIER AS THE PAPER IS JAMMING AT THE SORTER. I DO NOT NEED TO SORT. i WAS NOT ABLE TO FIND THE MINOLTA EP 1080 HOPE THAT THE EP 1083 IS SIMILAR ENOUGH. THANKS.
  • sam gerban
    sam gerban May 11, 2010
    yes you can if thats all you want to know???????
    Problem Solver:
  • 3 Answers
Tur off the sort indication green light on the control panel , and even you unpluge the sorter connection from the machine the paper it still going out from the sorter without jamming.
Posted on Nov 26, 2008
  • 145 Answers
You can disconnect the sorter.if that's all you need
Posted on Oct 18, 2008
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
I have a Toshiba 3550 w/ malfunctioning mg-1003 10 bin sorter. I would like to disable the sorter and run without it. I was told to change system mode 4 from 1 or 2 to 0. It was already set to 0. Which...
Please check out these codes and descriptions, if they are ever helpful.
C01 Main motor drive problem C21 Optics problem Scan , lens, mirror C26 Exposure lamp detect problem C32 Setup error (UA) C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem C54 Communication problem between sorter and machine main board C55 Communication problem between ADF and machine main board C71 ADF drive problem C72 ADF registration sensor problem C73 EEPROM initialization problem C81 Sorter paper conveying motor C82 Sorter bin motor C83 Sorter upper sensor C84 Sorter lower sensor C85 Sorter home sensor C86 Sorter copy removal sensor C94 Optics initialization problem in test modes E01 Paper jam E02 Fuser jam E03 Paper jam E05 Paper feed jam E14 lower cassette jam E71, E72, E73 ADF jam E75 ADF jam of 2nd original E81, E82 Sorter jam
Good luck.
May 23, 2010 | Office Equipment & Supplies
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Trouble getting ''copy'' from copier to sorter. gets stuck in btwn
Clean the exit parts rollers,lever and the sorter roller and bins.
Nov 23, 2009 | Office Equipment & Supplies
Paper not feeding through sorter portion of copier
Where exactly is it jamming?. type of paper,2-sided only?
1. First unplug from wall for 20 min.
2. clean the rollers with alcohol, or electronic cleaner. NOT CONTACT
CLEANER, Rubber rejuvenator. If your are a Print Shop use blanket wash. especially the two long rollers between the sorter and copier. Use
canned air to blow dust from all all parts especially sensors. If this only works for awhile you may need to replace rollers. If no paper at all enters the sorter it has to be a stuck paper. somewhere.
Aug 12, 2009 | Canon imageRUNNER C3220 Color Copier
Paper keeps jamming between the doc feeder and sorter, and fax does not work.
The Sorter is either disconnected or out of alignment. look behind the machine there should be a cable from the main unit to the sorter. Check it for connection, also make sure the sorter or inline with the machine. and all access doors are closed.
Hope this is of some help.
Ed
May 26, 2009 | Ricoh Office Equipment & Supplies
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
Toshiba 3550 Document Feeder
1- you've already established that the jamming is coming from the sorter, since you said they jam as they exit the copier into the sorter bin.
2- check to see if the sorter is aligned, is one side higher than the other? is it crooked? are the wheels of the sorter turning as the paper exits the copier, is it plugged into the copier? does it show "connect sorter" when detached from copier?
if not the sorter board may be bad.It may need to be aligned ( not easy if not used to doing.)
Nov 25, 2007 | Office Equipment & Supplies
107 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
