Question about Hoover U5453-900 WindTunnel Supreme Bagged Upright Vacuum
Hoover model U4258-930
I replaced the belt and lost suction. The aren't any blockages. What could be the problem?
informatica
  • 1114 Answers
SOURCE: need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 28, 2007
reddevil6
  • 1673 Answers
SOURCE: hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Posted on Jan 29, 2008
SOURCE: Hoover Alyx Pets 2000w Hoover Model
not getting any suction. there are no blockages.
Posted on Jul 21, 2008
wayneard
  • 1901 Answers
SOURCE: hoover upright model u5095-930 belt change
I couldn't find your specific model but this may be similiar to another that you have to position the new belt around the agitator (beater bar) on the bottom of the vacuum, replace the cover, and then turn the vac over and remove the TOP cover to lift the new belt up and place it on the motor shaft/pulley. The new belt may require some effort to pull it over the pulley.
Hope this helps.
Posted on Oct 29, 2008
dragonsthatk
  • 547 Answers
SOURCE: hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Posted on Feb 12, 2009
My vax pet Hoover has lost its suction I've emptied it there's no blockages and Iv cleaned the filter
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction.
Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Jan 09, 2016 | Hoover Vacuums
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
HOOVER VACUUM U8173-900
1) check the hose for blockage.
2) see the belt is slipin to due worn and replace .
3) check the bag/tank for full and need empty, and replace.
However go to the
http://hoover.com/support/video-instruction-guides/
and use the troubleshooting with common senses.
God bless you
Sep 06, 2012 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hi my dc07 has lost suction on the roller, but not on the hose there are no blockages cyclone still strong any ideas thanks
Are the brushes in the base of the vacuum spinning? You wont get much suction from the base of the hoover if the brush bar isn't working?
Lie the vacuum on it's side and turn it on. If the brushes aren't spinning then your belt has either come off or broken. I suspect this is the cause of your problem.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
There is no suction
check for blockages and clean your filters
Jun 24, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
I have a u3450 1500w hoover, suction on hose works fine, but carpet suction has never worked, how can i fix this?
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Nov 02, 2008 | Hoover Vacuums
Hoover U5453-900 WindTunnel Supreme Bagged Upright Vacuum Logo
99 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
