Question about Radio Communications
Madcats bluetooth headset for ps3 - replacement charger
Does anyone know where i can buy a replacement usb charger cable please for the above?
Ebay could work. you could even check with the company.
Posted on Dec 03, 2010
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
Okay i have the mad catz 8806 mic it flashes red and blue and charges fine but i cant talk into it and cant hear anyone through it at all it beeps and i hear that.
If the headset you have is the Item No. 8860 in order to use it you have to pair it.
If you are using it on a PS3 then be sure that you have selected the headset in the PlayStation's settings.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Troubleshooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Hope it helps
Apr 06, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
I lost the charger for the jabra bt135 bluetooth headset...where can i buy a new one?
Hey there sanjeev! There should be an USB port on the back of the headset, it is the micro-usb port. Therefore, if you have a cable from your camera, mp3 player or any other gadget that uses a micro-usb port, take their cable, plug it into the headset and let it charge! :D
I hope it helped! Take care! :)
Mar 04, 2011 | Jabra BT135 Bluetooth Headset
I cant connect my headset
Have you charged headset via usb cable plugged into ps3...when charged press + hold silver telephone symbol...a blue pulse light should appear on headset..go to menu in ps3..to pair devise [headset] with Bluetooth.
Feb 26, 2010 | Mad Catz Bluetooth Headset for PlayStation...
Lost charger who can I call?
The nice thing about the ps3 is it can charge the bluetooth from the charge cord for the controllers. Just plug the bluetooth into the charging wire from the ps3 and the bluetooth will charge.
Jan 27, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I have lost my A.C, charger
Almost any outlet that sells Cell Phone accessories. Motorola Bluetooth Headsets mostly use a Mini USB, and older ones used a two pin connector. Determine which one yours has and match it up, you can even buy one on Fleabay.
Jun 14, 2009 | Motorola Mobility Bluetooth Hands Free...
Controller and consolle
You can try hard resetting the controller.
Flip the controller over, and press the reset button. It's to the right of the middle-top screw ps3_controller_reset.jpg. You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
I've read that not allowing the controller to die will help prevent this, so try and keep your controller charged 16x16_smiley-very-happy.gif
If that doesn't work, another issue might be your cell phone and bluetooth headset (especially if you have the headset also connected to your PS3). Try turning off the headset, or if you use the headset on your PS3 as well as your phone, turn off your phone's bluetooth adapter. I was having this issue when I was using my Plantronics headset with my PS3 and cell phone.
Got this info from Kaivarri.
Let me know if that helps, if not let me know and I'll give you some more tips. Please don't forget to rate.
Thanks!
Feb 23, 2009 | Sony Playstation 3 (PS3) Console
Radio Communications Logo
398 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
