Question about Canon Cameras
Battery rechargering - Canon Cameras
    Master:
  • 383 Answers
Battery Recharging ...thats Good ... When gets charged fully .... Use It
Posted on Oct 16, 2008
Can rechargeable battery be replace and is it economical to do so?
if its rechargeable why replace it just recharge it. depending on what it is in you may be able to find a replaceable regular battery for it, or the rechargeable battery that is in the component maybe bad and won`t take a charge. there fore you should be able to find a battery that is the same. rechargeable batteries do have a life span.
Mar 28, 2015 | Camping, Backpacking & Hiking
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Does the garmin need a ion battery to work?
jon battery is inside, may have flat charge, try recharge waiting more;
jon battery protection recharging circuit, may be broken or battery pack loose minimum voltage to be recharged, about 2,5 volts.
SAFETY recharge range of jon batt. is 2,8 to 4,15 volts.
Apr 23, 2014 | Garmin NUVI 360 GPS Receiver
Battery charging
Hi Patrick,
A rechargeable battery will eventually fail to accept a charge - just like your car battery.
The number of recharges a battery will be able to accept is dependent on a number of things, such as: temperature, if it is run to almost nothing before recharging (or if it is recharged after only being discharged slightly), how much of a load is on the battery and how fast (high amperage) or slow (low amperage) the battery is recharged.
Generally, cooler temperatures are better for batteries, as is using the battery almost completely before recharging rather than topping off after minimal usage, small loads are better (you don't have a choice in your GPS watch tho) and a slow or "trickle" charge is better than a fast, high current charge (you may not have a choice on this either). A few hundred discharge / recharge cycles is not uncommon - significantly less if the battery isn't cycled properly or used in harsh conditions.
I hope this helps!
Jul 01, 2013 | Bushnell Neo Plus GPS Watch
How to replace battery of wireless laser mouse mi
On the Top on the Mouse u can see the Battery u need to Remove the old Battery's and Replace with New battery see that you use Rechargeable battery because ordinary battery life spam is very less and u need to change the batterys for every 1 month so if u use the rechargeable battery then u need not change battery for 1 month at least for 5 or 6 months the rechargeable battery work and u can keep and spare rechargeable battery when every needed and try to purchase a Sony Rechargeable batterys deepakkumaar.jpg
Dec 14, 2010 | MSI Computers & Internet
2006 dodge durange wont start tried to recharge
Some times battery's are beon recharging that recharge wont do it, after you recharge battery turn your lights on, if very dim or dont come on, battery is no good replace it, also try to start it it if lights go off, replace battery.
Jun 23, 2010 | 2006 Dodge Durango
What symbol is used when the battery needs to be recharged? Is it ok to recharge the battery before the symbol appears?
battery's life is governed on the number of recharges. so it is always recommended to recharge a battery only when it has been discharged completely. generally a blinking battery symbol denotes that the battery needs recharging.
Aug 07, 2009 | Olympus Stylus 710 Digital Camera
Honeywell CT200A thermostat battery will not recharge.
Yes the battery charge circuit is burned out, you might as well replace the thermostat, parts will not be made to fix it unless it is still under warranty.
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Sp 350 battery
It Needs a Lithium battery- only lithiums have the density to cope with the demand - no need to buy expensive Olympus Originals
Try www.sevendayshop.com for starters
Plenty  of sellers out there.
Oct 14, 2007 | Olympus SP-350 Digital Camera
Is the battery that comes with the camera rechargeable?
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
