Question about Sony Handycam DCR-TRV900E Mini DV Digital Camcorder
Audio problem I have an extenal mic plugged into the correct socket & have done a test recording. When I play it back the sound is intermittant How can I get the sound quality right? At the moment you can only hear evry other word!
    Master:
  • 383 Answers
The Pin or the Wire Or the Socket Seems to be the Problem ..... Please Use a Cleaner liquid on a Ear Bud And Clean contacts of the socket and the Pin and then try again
Posted on Oct 16, 2008
I got a sentry industries headset but the mic isn't working on skype it say on the box that it works with skype but when i connected the mic it wasn't working in skype . please help me how can i...
try to to see if it is plug on the right mic socket, usually pink. and make sure that you record directly on your mic,
go to control pannel choose sound and audio devices (on vista and window 7 just search for sound and devices or the volume control on the startmenu), and click on the advance button.
choose option properties and choose recording
make sure that you check the mic and increase the volume as musch as possible
try to adjuct the mic setting on the skype by calling the sound test service
May 09, 2011 | Office Equipment & Supplies
I have a HP laptop, and the internal mic has never worked? is there an upgrade i need? also, is the sound card automatically in the computer or is that something extra? i thought since it had the internal...
Changes in software, settings, or drivers can cause a microphone to stop working. Before performing any of the solutions in this document, test the equipment. After testing the equipment, select the document section that applies to the issue and follow the instructions. If the microphone recently stopped working, it may be necessary to use the Microsoft System Restore feature to correct the problem. Windows Troubleshooting Windows troubleshooting can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run Windows Troubleshooting first before you manually correct problems. To run Windows Troubleshooting, follow these steps.
  1. Click Start , enter troubleshooting in the search field and select Troubleshooting from the list.
  2. Under Hardware and Sound, click Troubleshoot audio recording and then click Next when the Recording Audio window opens.
  3. Select the device you would like to troubleshoot and then click Next .
If a recommended action displays, select Apply this fix or Skip this step to continue to search for other problems. If your problem has not been resolved, continue to manually troubleshoot using the rest of this document.Test the equipment Verify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
Dec 01, 2010 | HP Pavilion dv2000t Notebook
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
May 15, 2009 | HP 510 Notebook
No Sound When Recording
Video camera has built in microphone which is on at all time until you plug in different type of mic then camera is switched to new mic. Audio problem may be on audio head or circuit problem. You can test the system by playing pre-recorded tape to see if it play with the sound and go from there. If it play but does not record sound, you have audio recording problem. If it does not play, I would clean the video head and audio head area good. -James For further assistance, request help at www.camerarepairjapan.com
Apr 11, 2009 | Panasonic Video Cameras
I can not use my computer microphone for live talk my computer acer aspire 5570z, other person to whom I talk can not hear my voice
Make sure the microphone jack plugged into the right jack socket
and that the microphone is plugged into the socket at the front of the pc.
In WinXP go to Control Panel\Sounds and Audio\Voice\Test hardware, this will test your mic by recording from it and playing it back.
If you are using a sound card go through the software setting.
Jan 01, 2009 | Computers & Internet
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
No sound through M-Audio preamp and condenser mic
Hi micoach
The condenser mic you are using requires phantom power for it to operate. Pay to check that that is turned on m-audio. Just to be sure.you say you can get sound off the m-audio headphone socket. Just need to check that. You will need to check that you have selected the device for recording from the preferences--audio I/O options menu within audacity. Perhaps check these things and get back to me here if you still have problems.I can go into more detail with you.
regards
robotek
Jun 30, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
NO SOUND ON PLAY-BACK
I had a similar problem but I just plugged in some heaphones into the mic and I got everything in the DAW to play back through them.
May 18, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Logitech Quickcam Chat - No audio
Try testing it, last time I checked skype has a test section, its hard to find, but its there. You just talk into the mic and skype records it. Then play back.
It is possible the mic isn't working.
Before you consider taking it back, make sure you follow the instructions to the letter.
Dec 25, 2007 | Logitech Quickcam Chat Webcam
Missing Audio
sound changes to external mic. when any ex. mic. is inserted the internal mic. comes out of order then you don't and can't have two sounds same time that mean you only get the ex. mic sound regards please don't forget to rate thx
May 02, 2007 | Canon MV630i Mini DV Digital Camcorder
Open Questions:
Sony Handycam DCR-TRV900E Mini DV Digital Camcorder Logo
53 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
