Question about LG Electronic Window Air Conditioner
FREEZING : MY AC IS FREEZING UP AT NIGHT
  • 958 Answers
Check your thermostat, could be set to the coldest setting and it is not cutting off.
thermostat could be broken also( stuck close)
the evaporator coil could be clogged with dirt. have it clean.
tnx 4 using fixya,
drcool
Posted on Oct 16, 2008
The coils are freezing overnight
Dirty filter,undercharged, evap. coil plugged.These are some possibilities, also tstat may be set to low adjust to reasonable temp
Apr 01, 2015 | Heating & Cooling
Dometic AC cycles on and off
sounds like you don't have enough of a charge in the system of "free-on". that would make the a/c cycle and cycle to try and keep the pressure up and would also contribute to the lines frosting and freezing
Jul 04, 2012 | Dometic Rooftop RV Air Conditioner
WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO...
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
Sep 28, 2010 | Heating & Cooling
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
Ac unit keeps freezing up owner says only at night
A/C's freeze up due to low air flow or low refrigerant charge. Check your air filter and make sure all your registers and vents are open and not blocked. You may need a service tech.
Aug 13, 2009 | American Standard Heating & Cooling
Brand new Dometic rooftop ac,freezes up at night,does fine during day...??
This is common for most air conditioners and is normal due to humidity levels being higher at night causing more condensation build up and then freezing. Solution: Turn down thermostat at night to allow compressor to turn on and off.
Jul 26, 2009 | Heating & Cooling
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
LG Electronic Window Air Conditioner Logo
96 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
