We have 2 computers in our home and we just had high speed installed through our local cable company. one computer works which is connected to a modem and router. the other was set up wireless with an adapter. it does not work. I have called HP for assistance and nothing helps. I get errors that the device manager doesnt work, the virus protection doesnt work and the firewalls can't be fixed. what else can be done
    Genius:
  • 1,124 Answers
Did you see the wireless signal or your network status in the computer with the wireless adaptor?
If yes, select your wireless network and connect your device.
If no, check the status of your wireless card first
My PC >> Properties >> Hardware >> Device Manager >> Network
If the wireless is marked ( ! ) Install the right driver for your wireless card
If ok, try to set up your wireless connection with windows wireless utility instead of HP utility.
(if necesary uninstall HP utility)
If the firewall can't be fixed this issue is related to your antivirus that it is blocking the setting.
Let me know how it is going...
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Posted on Oct 16, 2008
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
Tip
My Internet connection so slow?
<p>The type of Internet connection you use is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up. <br /> <p>Many Internet providers also offer Fiber Optic Service (FiOS), which connects to the Internet using light over an optical network. In your home, you still connect your computer through copper wiring. The advantage of FiOS is that it can provide higher speeds than traditional copper wire connections such as DSL or cable. Some Internet providers offer multiple options, depending on the area you are in. More populated areas are more likely to have FiOS available. Check with your phone company or Internet provider for more information.<br /> <p>If you use a dial-up connection, there are a couple of good ways to optimize your Internet speed. First, use the fastest modem you can. The fastest modem you can use will send and receive information at a rate of 56 kilobits per second (Kbps). You won't get a full 56 Kbps speed most of the time, but with a good phone line, you should approach at least 45-50 Kbps. <br /> <p>Second, make sure that your phone line is in good condition. If the telephone wiring in your home or business is old or deteriorating, you might be picking up stray signals or cross talk from other phone lines. These problems will slow your Internet connection because the modem will have to send the same information over and over until it's transmitted without interruption. Check your telephone wires to be sure they aren't damaged, frayed, or twisted around power or other telephone cables. If you notice crackling in your phones, you might want to contact your phone provider to have them check the lines inside and outside your home to make sure they are in good condition.<br />
on Dec 03, 2010 | Computers & Internet
Need to connect to internet through comcast cable where is the ethernet connection on the machine
hi
yes there is ethernet connection bilten in mother board just chack back site of your CPU
May 16, 2010 | E-Machines T1100 PC Desktop
Ethernet port does not work in computer. The cable company set up a USB connection which worked, but now I installed a wireless router. The ethernet cable from the pc to the router does not show a...
Here are some things to check.
  1. In the system setup, ensure that the network adapter is enabled.
  2. Check device manager and see if the driver is properly installed.
  3. If the integrated NIC doesn't work, you can disable it in the BIOS and install a PCI NIC (Less than $20) and the system will work that way.
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
No high speed usb port
Hi Delvin!
The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
Here you can read about the "high speed usb" :
http://www.usb.org/developers/usb20/
And here is the manual and avalible drivers for your Dell:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck to you M8!
Please take a moment and rate my help for you
Nic
Feb 23, 2009 | Dell Dimension 1100 PC Desktop
I already have verizon internet"fios' how ever i want to purchas cable for my hd tv
Usually Verizon can offer HD TV over the same FIOS cable. If you call them, they can connect it to your TV for you.
If you call the cable company they can probably set up cable for you. The two shouldn't interfere with each other.
Jan 25, 2009 | Computers & Internet
Modem for dial-up
Well I hate to be the one to break the news but their is no such thing as a fast modem. They are all 56Kbps which is slow....the only fast modem is a DSL modem, but that is outside the computer and it gets hooked up with your phone company or your Internet Service Provider. Check the invoice or packaging slip and see if it says "DSL Modem capability"..if so then you are ok but your ISP has to install it.
Dec 28, 2008 | Gateway Computers & Internet
WHEN I TRIED TO HOOK MY COMPUTER UP IT WAS WITH A ROUTER AFTER NOT BEING ABLE TO GET IT TO WORK I HAD MY CABLE COMPANY TO PUT A CABLE HIGH SPEED BOX ON IT NOW THE ROUTER KEEPS INTERFEARING WITH MY...
Its annoying if that pop-up every time you surf the net.. there is a configuration in your router software or software installed by the cable company, set not to notify you every time you connect to the net... try check the configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
I recently purchased a Hawking HSB2 Signal Booster. Two years ago, my son installed a Toshiba Cable modem(PCX2200)and a Belkin Wireless Router(model#F5D7230-4)for Camcast High Speed Internet. The Router...
Booster will only work along with access points in your case the belkin wireless router - you have to connect the device to the router not to the windows xp pc
if you know how to configure and the device are compatiable to each other and allows bridging or can configure as your access point client then you need not wanna to get it connected via wire or T568b standard ethernet cable otherwise you have to connect with this cable will enchance the wireless activity
Wireless signals can go down its strength by any magnetic activity, oscillations such as microwave, powerful steel/metal frames and check your anteena position keep in different direction and check your pc wifi signal strength.
Interlink between your router and booster with utp cables gives you steady flow of data and full band strength.
Aviod using two company devices change the router to Hawking
Thanks Hothawk
Jul 24, 2008 | Computers & Internet
My modem with dial up but not high speed
You might need a new NIC card, thats high speed capable. What kind of hi speed are you trying to use ex.DSL,FiOS,Cable?
May 16, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
