4x6 photo paper gets jammed in the tray. Is there an adjustment that can be made? Model mp600
    Genius:
  • 1,605 Answers
No. all you can do is very carefully remove the jammed paper with a needle noise plier. (first open the cover and take out all of the paper tray). and make sure the paper path is clear.nothing stucked in the corner or under the roller.
Posted on Oct 16, 2008
Can I get a replacement 4x6 paper tray?
Brand name model type and other associated data might be helpful to assist you in your goals.
Jul 03, 2015 | Office Equipment & Supplies
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
    At the printer:
    1. Remove any paper from the input tray
    2. Put a few sheets of 4x6 (10 or so) in the same tray
    3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
    On the computer:
    Open a picture
    Seect [File] [Print]
    Select the photo printer from the list
    Cick on [Preferences]
    See the paper type? select photo paper
    See the paper size? Select 4x6
    Quality (Best)
    [OK]
    [PRINT]
    Sep 28, 2009 | HP Office Equipment & Supplies
    Problems printing 4x6 with MP600
    You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
    Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Paper jam
    Remove the paper following the procedure below.
    (1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
    Do not load it in the landscape orientation.
    (2) Turn off the machine.
    (3) Turn on the machine.
    The paper is fed and then pushes out the jammed paper as it ejects.
    If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
    James Mac
    Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    Printing photos
    Of course you can use 4x6 photo paper
    you have select the paper size from page setup as 4x6
    and put the paper in the tray after adjusting the tray size
    Dec 27, 2007 | Samsung CLP 300 Laser Printer
    MFC-5440CN 4X6 PRINT
    mabey try using windows, not linux, make sure you have driver and other software on CD.
    Jul 21, 2007 | Brother MFC-5440CN All-In-One InkJet...
    82 people viewed this question
    jasbo
    jasbo
