Question about Nintendo Wii Console
How do you turn on the Wii controllers???? They arent working for me
My little nephew has the new Wii system. He is at school right now and I am trying to play his games. I turned on the system and set the TV to the correct station to be able to play. I have the Wii Main screen up and running. Only problem is.... I cant figure out how to get the controllers to work. I changed the batteries in each controller. Still nothing. At the bottom of the controller, when I press ANY button on the controller, the 4 little squares light up blue at the bottom. I dont know what to do here. I need a little help. Please Please Please, If you know how to get them working, please fill me in. Thanks.
  • bhfoo Nov 06, 2008
    have pushed the red buttons on the remotes plus on the control box . remotes still do not work
  • OSREALTY Nov 28, 2008
    I LEFT MY CONTROLER AT MY COUSINS HOUSE AND I CANT TURN THE OTHER ONES I CLICKED A BOTTON AND THE LIGHTS TURN ON AND NOTHING SO PLZ HELP ME
Look inside an little slot on it then click it with the red circle on the back of theremote by the batteries
Posted on Oct 16, 2008
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
My nephews wii wont spin the disk,, it will take the disk in and eject it but throws up an error when you try to play the game, i am an electronics tech in the navy and figured the drive motor was bad so i...
The motor didn't go out, the laser itself did. The laser is what actually controls the motor spinning.
Swap the laser out and you should be good to go. I find it's easier to swap the whole drive out complete. It will cost a little more but it's well worth the time and frustration you will face ;)
-- Rescue Tech
Jan 13, 2011 | Nintendo Wii Console
We just purchased 2 new wii remotes to add to our system .......(of course the kids threw the boxes away with the Christmas paper --NOT GOOD) we have tried numerous brand new batteries ......tried...
Frist make sure your batteries are right size and installed the right way. Then turn on your wii press the A button at this point you should see lights at bottom of controller. Now push the sinc buttons on the controller and the wii system and you should be set.
Dec 31, 2010 | Nintendo Wii Console
I am having trouble to connect my wii controllers to the wii how do you get it to connect
YOU PRESS 1 AND 2 AT THE SAME TIME IF THEY ARE ALREADY PRE CONNECTED TO YOU SYSTEM BUT IF THEY ARENT PULL OFF THE WII BATTERY COVER AND YOU WILL FIND A RED BUTTON.. THEN OPEN UP THE LITTLE SLOT UNDER THE INSERT DISK TRAY AND PUSH THE RED BUTTON THEN PUSH IT ON YOUR CONTROLLER IT SHOULD CONNECT THEN... BEST OF LUCK.
Jul 31, 2010 | Nintendo Wii Console
My wii controls have stopped working with chargers and batteries but still flash as if they are going to work then they dont
they just arent registered with the wii. first open the battery door on the wiimote (control) and press the little red button. then open the SD card slot on the wii and press the red button there and the wiimote will connect
Apr 26, 2010 | Nintendo Wii Console
We do not know how to charge the remotes for the Wii using the competition pro charger. We place the remotes on the base but the blue lights on the side aren't illuminated and the charge doesn't transfer...
the batteries in your wii remote..... are they rechargeable batteries??? if so then there could be a malfunction withing your comptetition pro charger.... however if they arent rechargeable.... try putting rechargeable batteries in the wii remotes!
Feb 17, 2010 | Video Game Consoles & Games
Hi my wii remotes arent working please help
Possible scenarios:
Out of battery:
Solution:
Replace batterries
Connection has been intercepted:
Solution:
Take the back off of the remote and then go to the Wii and open the little compartment left of the Wii. Then press the red button on the Wii remote and console simultaneously untill something happens like, connection restored on the Wii screen.
Dec 30, 2009 | Nintendo Wii Console
Wii is comming on but when it says press a button nothing happens new controls aren't working or sensor bar isn't picking it up what to do
You probably need to synchronize your Wii-Motes to your system. When you press buttons on your controllers do the four LED lights flash at the bottom? This is a clear indication. Your Wii needs to be turned on. You need to open the little door on the front of your Wii where the SD card slot is. Under the slot there is a little red SYNC button. Then open the battery compartment on the backs of your remotes. There is another little red SYNC button here. Press the button on the remotes and then while they're flashing on the Wii and it should sync. If it doesn't work the first time try again.
Dec 22, 2009 | Nintendo Wii Console
HSM Sing It Microphone does not work
Have you tried going to the screen for Mic sensativity?? It will help you set the mic control. this is inside the HSM sing it game, not on the system itself.
Dec 12, 2008 | Disney Interactive High School Musical:...
Wii controllers
Sounds like the remotes aren't sync'd up with the Wii in a way to turn it on. I had a strange occurrence with ours where only 1 Wiimote (ha!) out of 4 would turn on the Wii with the power button. Try following the instructions to program the Wii to the Wiimotes again and see if that works. Also try holding the power button on the remotes a little bit longer.
I don't recall but you push the red button behind a hidden cover on the front of the Wii and then the button on the Wii controller behind the battery cover.
Dec 31, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
