Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Not filling washing machine will not hold water, continues to fill and drain at the same time
  • shortjabba Oct 17, 2008
    it is in a drain pipe
  • john gagnon
    john gagnon May 11, 2010
    HI thanks for your question. how high is the drain hose from the floor. is it in a drain pipe or in the sink
  • 943 Answers
How far down the drain pipe is it down . lift the hose out a bit to see if it stops
Posted on Oct 17, 2008
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Can not hold wash temps at 150 degress F.? Once filled the resorvior tank stays filled, but water continues to run out main drain?
If it's drain water and filling with water at the same time your drain hose is lower than the water fill line of the washer. try raising the drain hose up higher
Jan 26, 2010 | Hobart 42 in. AM14C-154 Free-standing...
It won't hold water just keeps draining even while its filling. I bought a frigidaire stacked washer dryer and i just hooked it up today everything works great except when i turn it on it will work normal...
help is on it's way ... the drain hose needs to be 36 in high. . if it's too low it will drain and fill all day . you can use a drain ext. or longer hose if needed. if this does not correct problem / were still here . mm
Nov 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
