Question about HP vs15 15"LCD Flat Panel Monitor
Monitors blinking my hp lcd monitor is blinking. please give a solution. Thanks
    Problem Solver:
  • 9 Answers
Is it a laptop or a desktop?
Posted on Oct 16, 2008
Don't light, y no LCD connected, them blinking
Edwin kicked and broke the monitor. Then he charged $760. Touch screen has a big crack.
Nov 03, 2012 | Computers & Internet
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
When i start my pc, it shows monitor going to sleep, again & again please give me solution
I think you system is infected. Try restoring your system to the date which it worked fine or a formatting will be necessary. please rate my soultion. thanks
May 10, 2011 | HP w1907 LCD Monitor
I have an hp 1502 LCD monitor. a weak before it start problem, as when i on it the screen goes blink white just after having a glimpse of the desktop view and when i do on and off it for several times it...
This is the inverter board problem. There is an inverter board inside LCD monitor. Most probably the capacitor has gone bad. There is no way you can fix it (unless you are a qualified technician). Please take help of HP service center or call a person who repairs LCD monitors.
Dec 07, 2010 | HP w1907 LCD Monitor
Problem with monitor (blinks)
it sounds like the lcd inverter board may have gone bad- its what powers the back light on the monitor similar to a flourescent light. usually its fairly cheap to replace (around 25 used on ebay) typically its located inside the lcd bezel on the bottom center.
Nov 01, 2009 | HP Pavilion dv4000 Notebook
HP vs19 monitor does not turn on.
You may have to inspect the inside of the monitor. You may have to dry it out from the inside and look for burned component which may be caused by a short due to the moisture.
Aug 15, 2009 | HP vs19 (Silver) 19" LCD Monitor
Hp vs 19 lcd monitor and it randomly just turns off and then flashes back on for 2-3 seconds then goes back off again
phantasighz, Did you swap out the monitor to get online? Or has the HP LCD mysteriously start working fine again? We need a littile more history here???? Once the LCD goes to BLACK, will it stay black, or will it all by it's self try to start up again, and then repeat the whole cycle again forever? Did you buy it new? How old is it? Have you talked to HP to see if they have swapout program? You send them your's+$40 to $90, and they send you same model refurbished(new CCFtubes/inverter/smps) installed. If you don't know by now, you are dealing with a lighting problem. Do you have any of the new energy saving curlie-Q screw-in compact-fluorescent light bulbs? Their high voltage source is derived alittle different than the way your monitor does it, and of course the Cold Cathode Fluorescent tubes are thinner and straight and hung horizontally on the opposite side of the LCD/FPD you look at. All you need to do to learn more about your problem and what hundreds of others are doing to repair their LCDs is GOOGLE search this: bad caps in lcd monitors. Hope this info helps you understand the technology better. I'm louie12fix on fixya or lmistyrel
Apr 14, 2009 | HP vs19 19" LCD Monitor
I have a problem with hp crt monitor can't display caracter but only light like rainbow on the screen can yaou give me solution please thanks
Well, it is time to upgrade to a LCD flat screen monitor... The one you got it's busted.... You get buy one 19" LCD monitor less than $200...
Dec 01, 2008 | SAMTRON 55V 15" CRT Monitor
LCD monitor dirty
please give me a power supply smd ic nomber please MODEL NO. HP VS17E
Jun 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
