Question about Car Audio & Video
Protect light on car audio amp wont come on green light is on
  • 86 Answers
If the Protect light is on, that would be bad, if the green lights on you've got power thru your amp, meaning you have a good connection
Posted on Oct 16, 2008
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
My amp is stuck on protect mode. what do i do? its a lightning audio. the green light is not on the only light is the red protect light
the amp will need to be repair because it has a fault that it is seeing internally. so not much you can do other than buy a new amp or get that one repair. probably cost effective to buy new. hope this help. good luck
Nov 03, 2009 | Lightning Audio B2.300.2 Car Audio...
Red protection light wont turn 2 green no matter what so the amp wont work
Hello mcis43fan,
The protection circuit can be activated by shorted or grounded wiring or it can be caused by a defect in the amp itself.
First, disconnect all wires except power, ground and the remote turn-on lead and see if the amp powers up normally. If it still goes into protection, the amp is defective, most likely shorted outputs and needs repair or replacement. If the amp powers up normally, test the other wiring for shorts and grounds. You can reconnect them one at a time to determine which one is causing the problem.
Hope this helps.
Aug 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Hooked up to a kicker L712. Worked fine now its in protection mode. When i turn it on the light is green for a second then turns red. It wont stay green. What should i do? Is it the circuit board?
perhaps you are pushing the amp to hard check that the gain control knob is not turned all the way up. This will cause the amp to overheat. If not that check all of the wiring to the amp for a possible short.
Jun 05, 2009 | Sony XM-2200GTX Car Audio Amplifier
Dub 2502 not in protect mode but not putting out
i dnt knowwat type of speaks u got but ifits low then it cud be tht u have too open up the second coil on ur speakers...dnt sound like the amp since its on & not in protect mode,other than tht i'll recheck the wiring
Apr 07, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Amp is in protect mode, green light is on.
If the amp is going into protect, it likely has shorted output transistors. To eliminate other possible causes, read through the following page.
Amp in protect mode - troubleshooting
Let me know if you have any other questions.
Nov 29, 2008 | Phase Linear UPA424CS Car Audio Amplifier
My amp wont work
The amp probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Nov 24, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
