Question about Car Audio & Video
I own the acura legend model 94, my battery was dead so need to get it charge later saw that my music system not working it need some kind of code which i don't have it so pls help me in fixxing the problem
    Problem Solver:
  • 13 Answers
Go here to get it: http://www.tegger.com/hondafaq/radiocode.html
Good luck
Posted on Oct 17, 2008
Where is the obd diagnostic port on a 94 vigor.
Acura engine codes - Howstuffinmycarworks.com
www.howstuffinmycarworks.com/Acura_engine_trouble_codes.htmlOn OBD-II models, the check engine light is referred to as malfunction indicator light (MIL). ... On Legend coupes, 1991 and later Legend sedans, 1990 through 1994 Integras and all Vigor models, ... 23- Front knock sensor ( some NSX, Vigor)
Sep 01, 2015 | Cars & Trucks
I NEED TO DECODE MY AUDIO SYSTEM STD.MODEL FOR A 1992 ACURA LEGEND
your book should have a security code in it that you can put in after starting your car- after numerous times of failing with a code tho- the security will lock- unplug the battery and try again. i had this happen with my 98 acura tl 2.5
Apr 14, 2013 | 1992 Acura Legend
How do i change my igniton switch in my 94 acura legend?
To replace ignition switch on 94 legend, first secure the car on a level parking surface, engage parking brake, chock wheels for added safety. Disarm airbags, be aware of a coded radio / sound system, ensure that the 'disarming' code is available or it may be very difficult to reset the radio. Disconnect the Neg. battery cable from the battery post. Remove lower cover panel from lower dash on driver's side. Remove electrical connector from ignition switch. Ignition key must be used to turn cylinder from 'O' to 'I' when necessary to unlock cylinder from column (Steering-Lock Pawl). Remove 2 bolt / fasteners which hold ignition switch in place - it may be necessary to cut a grove into the top of each fastener with a hack-saw or high-speed-cut-off tool if fasteners are the original round-head type. Sometimes simply trying a good pair of locking-pliers with a tight grip will be able to loosten the bolts enough to remove them. Once the old ignition cylinder is removed, clean inside the cylinder opening, install the new cylinder & secure all wiring which was removed, secure switch with new bolts, test switch, replace covers & last of all, reinstall battery connection.
Dec 16, 2010 | 1994 Acura Legend
I need the radion code for my 1993 acura legend
I just bought my 3rd Acura Legend...but never encountered this problem. They removed my battery to place in another vehicle on the lot...and when they replaced my battery, the radio locked up and would not do anything. I called the Acura dealership in my area....have an appt for Monday, she said $51.00 to get code. I was reading on all the websites i could find about Acura radio codes...then i come accross one posting about an Acura Integra. It said her code was under her ashtray. I went out to my car...pulled my ashtray out. There was a white sticker with a 5 digit number first, and then an E number. I turned my radio on, entered 5 digit number...it BEEPED. I turned it off, and turned it back on...to the most WONDERFUL BOSE stereo system!! It worked ya'll!! I was so shocked!! It may not help everybody....but my Acura Legend 4Dr Sedan has MUSIC now!! So i thought i would pass it along...saved me FIFTY dollars!!
Aug 23, 2010 | 1993 Acura Legend
93 acura legend radio battery went dead in car and now flashing security light how do i get radio to work again anim assuming it needs a code an how can i get code for free
Jul 29, 2010 | 1992 Acura Legend
I need my code for my radio in my 91' acura legend
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Apr 18, 2010 | 1991 Acura Legend
1993 Acura legend bose radio wont come on or display for me to put in code.
contact acura or toyota , have your vin# handiy
they can give you the code and how to enter it
i assume you had a dead battery at some point?
Nov 22, 2009 | 1993 Acura Legend
94 acura legend idles fast and slow when initally starting
The butterfly valve inside your throttle body may be loose causing your idle problem. have it inspected to see if it is.
Sep 07, 2009 | 1994 Acura Legend
Need unlocke code foe boss car stereo
go yo youre nearest acura dealership and take with you proof of ownership and they will give you the code or unlock it for you no charge
Jul 25, 2009 | Car Audio & Video
94 Acura Legend-battery change no power to car only blarring horn
if you set off the alarm you have to use the remote control to stop it. some cars you cycle the passenger door twice and it will stop.
make sure the polarity is proper.
May 13, 2009 | 1994 Acura Legend
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
