Question about Hawking Wireless-G HWUR54G Repeater
Repeater not sending signal properly
Our hawking extender works on and off but last it stopped working completely. I spent an hour on the phone with tech support and they talked me through reconfiguring it. It worked for a short time and now is not working at all again. Occasionally the extender will show up on my computer as having excellent signal but yet I cannot connect to the internet. Even when it is working somewhat, it usually kicks me off when I log on to hotmail.com to check my email.
4 Suggested Answers
  • 48 Answers
SOURCE: Can't connect!
make sure its IE that you use the configure the extender config as using firefox may not save the settings. check if theres an option of save all settings within the config.
Posted on Feb 10, 2008
SOURCE: spontaniously lose internet connection to
We have solved our wireless connection loss by connecting the Hawkings by cable to the first computer needing a signal from it a second computer is able to connect to it OK, these two computers are upstairs and the main computer with router is downstairs this is working OK at the moment without the frustration of losing the internet connection
Posted on Mar 09, 2010
SamuRaiii
  • 130 Answers
SOURCE: I cannot connect to my
check cable, you need proper IP configuration
Posted on Dec 15, 2010
Hawking smart repeater pro
I CAN FIX THIS WITH A REMOTE CONNECTION...call 225-290-5733
Dec 26, 2013 | Hawking Hi-Gain Wireless-300N Smart...
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
I purchased a router linksys by cisco model wrt120n wireless home router, i leave on a 2 story house of concrete. my problem is i can not used my laptop on the first floor.. i look on the unit of my router...
You can use WAP4410N Access Point in Repeater Mode with WRT120N to extend the wireless signal.
You could also try the Hawking HWREN1 Hi-Gain Wireless-300N Range Extender.
Another route you can try is Linksys WMP600N High-speed Wireless-N PCI Adapter with Dual-Band.
These devices should each be able to give you a strong enough signal, if placed properly, to connect to your Router.
Mar 08, 2011 | Linksys WRT120N Wireless Router
Spontaniously lose internet connection to status "limited or no connectivity" intermittently and have to reset and reconfigure. this can be after 1 hour of use or several days
Jan 05, 2010 | Hawking HWREG1 Repeater
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
My laptop can't find the SSID
HI all, A couple months have passed since I posted this problem. I found my own answer after weeks of asking for help. The hawking Reg 1 repeater. Here's the answer. THE REG1 REPEATER ONLY WORKS WORKS WITH ROUTERS THAT OPERATE IN WDS MODE. Not all routers can. Check to seeif the router you are extending is capable of this mode. I tried 2 differnet routers, neither worked. Finally when I got one that spoke WDS. It worked like a dream. Why did the directions not say that!!!!!
Kayellynn
May 10, 2008 | Hawking HWREG1 Repeater
Can't connect!
Nov 15, 2007 | Hawking HWREG1 Repeater
Hawking Wireless-G HWUR54G Repeater Logo
63 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
