Question about Kenmore 73952 Gas Dryer
Dryer not drying cloths
This is a kenmore gas dryer. Mod. #11072612100. It is now taking 3 cycles to dry the cloths. I have diconnected the vent, and the air is hot coming out. The vent through the house is free and clear. Any Ideas.
  • 6 more comments
  • teamliechty Oct 17, 2008
    You are right, the housing was completly filled with debris. Thank you very much. I am running a load now to see that it worked.
  • Den K Oct 18, 2008
    I have a Kenmore Elite 11070052991. How do you clean the lint out of the compartment? Tried a vacuum with a crevice tool but it doesn't go in far enough. I do clean the lint screen with every drying, but there is a lot of lint that got beyound the screen. I also get an E1 message on the LED read-out.
  • teamliechty Oct 20, 2008
    No, the dryer is still acting the same. I ran a load of cloths and initially there was very warm moist heat directly out of the dryer, and at the exit of the vent from the house. Very good air flow as well. Half way through the cycle, there was no heat at all. I am assuming that a sensor is bad and the heat is being shut off?? Any more suggestions?
    I will give that a try and let you know.
    Thanks.
  • teamliechty Dec 01, 2008
    Replacing the two coils fixed the problem. Thank you.
  • gdutch Dec 04, 2008
    76512693
  • Anonymous Dec 11, 2008
    dryer does not dry clothes. the air is cold and will not warm up at all,check outside exhaust of dryer.ran it for 20 minutes.
  • Anonymous Mar 31, 2014
    Vent clear
  • 943 Answers
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Posted on Oct 16, 2008
  • john gagnon
    john gagnon Oct 17, 2008
    great glad i could help. is that a fixya.
  • john gagnon
    john gagnon Oct 20, 2008
    hi the coils at the gas valve are probably defective 2 black coils one with 3 wires one with 2 wires replace those the reason they went south is because of the constant on & off that they did when all the lint was there replace those thanks
Kenmore dryer model #110.62612101
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes;
I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster.
May 17, 2012 | Kenmore 74112 Gas Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Gas dryer not drying clothes
Hi, Dryers are simple machines to fix yourself so the main reasons dryers do not dry cloths is listed below.
1. Make sure the vent is clear from obstruction of lint built up by taking off vent and make sure the vent flap is opening when dryer is on, beware most house fires are caused by neglect of dryer vent!
2. People allot of times overload machine which causes cloths not to dry.
3. Electrical Repair Needed: one of the thermostats in the dryer are defective
May 02, 2009 | Dryers
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Doesn't dry well
it's not the dryer,it's something clogged with lint,the wall vent,dryer vent or lint trap or all 3,check them out-mike
Apr 25, 2009 | Kenmore 63012 Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Kenmore 73952 Gas Dryer Logo
308 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
