Wire of sensor bar pulled out by hoover,
The mother in law hoovered up the wire of the wii sensor bar.
I have opened it up to re-connect but I see no obviouse place to do so.
My son stripped the wire end to cut off a damaged portion so I don't know if the wires were originally bare.
one wire is copper colour the other is brass, do they connect or just clamp in place ?.
P B.
    Problem Solver:
  • 7 Answers
Buy a wireless bar then u wont have that problemm 14..99 at gamestop, wal-mart basically anywhere games are sold
Posted on Jan 03, 2009
    Problem Solver:
  • 11 Answers
Here's the best thing you can do:
Every Day Source has the Wireless Sensor Bar for Nintendo Wii for $4 with free shipping. Use code: WIIBARES .
Posted on Nov 07, 2008
Hi what does e11 mean on my hoover dynamic 6+5 wdyns 654 d mean pls?
Code E11 indicates an open circuit between the heater and the control board. The code also can indicate damaged wiring between the sensor at the top of the drum and the control board. The wiring can be damaged by drum rotation.
Feb 09, 2015 | Hoover Washing Machines
How do I change the belt?
To change the belt on a Hoover Flair Stick Vacuum, remove all 6 screws from the bottom of the beater bar. There are 2 screws hidden under wheels. You must pop the wheels off with a screw driver to remove the hidden screws. The cogged belt is on the left side of the beater bar. Be careful not to pull the wires.
Jan 22, 2013 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover vision hd not heating water
Please check the continuity of the element by using a multimeter, if open it must be replaced. if the element is good then the wires to the element and the mother board is a suspect.
check this link: Element
Jun 26, 2012 | Hoover Washing Machines
Replacing a belt Hoover wind tunnel
You will find four screws under the bottom cover. remove these. remove the beater bar, loop new belt on bar on pulley area. install the bar and then pull the belt over the motor shaft. re-install cover.
Oct 05, 2009 | Hoover Vacuums
Sensor bar inactivity on the wii videogame system
First you Should test with another sensor bar...try to take it from a friend to test it in your system...could be cracked wires from the sensor bar....try to test the wires with a multimeter and resolder the wires from the cable...or you can take your sensor bar and test it in another need to known if its really bad ,or if there is something wrong with your wii system...
Sep 09, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Mother in law needs the thermostat for her Hoover electric skille
Depending on the age of the pan. Call the company and ask if they have the thermostat. Give them the model #. You may need to do what I did and look up a local repair man to re-wire or solder.
Jul 28, 2009 | Rival SS166 Electric Skillet
Where is the filter on a Hoover softwave AC 270 washing machine
hi there,
here are top load washing machine parts are located.on figure 127dff9.jpgyou can locate where the filter was located,may be this will help you.,hope you can solve but if still not run,feel free to log in to fixya we are here to serve you better.have a nice day,rate my solution.thanks a lot.
May 19, 2009 | Hoover HTC243 Top Load Washer
Vac wont pull/**** anything while we try to vac floor,
Hello RonD30,
If you are getting suction thru the hose and not from the bottom section.. you have a clog somewhere inline with the base area... If you have access to a shop vac ... unplug the Hoover, open up the base and remove the beater bar /belt assembly.. then hold the shop vac nozzle on the point of entry to where the Hoover pulls the debris into the dirt compartment. I am fairly certain you have a clog somewhere in that ducting.. Stubborn ones may need a little motivation.. so you may be able to get an electricians snake or metal coat hanger bent to release the jam..
Hope that helps..
And you are right , regarding Lowes..but don't exclude Home Depot from the same rating..LOL Once the sale is done.. so are they...
Dec 13, 2008 | Hoover Vacuums
Hoover S3630 WindTunnel
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
Hoover Beater bar belt
Posted by rubyspider on Jul 05, 2008
I need help installing the beater bar belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 WindTunnel. All you need to do id to remove the bottom plate by removing either the screws, clips or levers and the bottom plate should come right off, and then you can get @ the belt – if not then the top cover will come off and then you can serv it from the top if needed. Then you can lift up the one end of the Hoover brushroll and then slide the new belt on to the pulley side of the brushroll and then use a belt puller or a screwdriver with a hook on the end and then pull the belt onto the motor pulley. Then track the belt in a straight line. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
112 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
