Question about Ricoh FT3713 Copier
Ricoh FT3713 E54
Flashes E54 which appears (from searching web) to be "fuser low temperature on early EPROM"
I'm mechanically proficient but know nothing about copiers. What can I do about this and where do I get parts?
Also, is this a good machine? I inherited it and it is probably 15 years old. Has worked well for many years.
Thank You!
Neil in Chicago
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 1,362 Answers
Sorry, not familiar w/that machine, but, low temp usually comes from the fuser unit (where the paper exits and the rollers get HOT).
All copiers have the same principals, my advice is to change the Thermistor in the fuser (it controls the temp)
one vendor that I use a lot is precisionroller.com
Posted on Oct 17, 2008
Ricoh ft3513 E-7 error code
The E tells you, it's an error. The 7 tells you what area to look in. My first guess is around the fuser and/or output assembly.
Aug 22, 2013 | Ricoh FT3713 Copier
Code error e54 copier.i need the reset codes
- Possible Causes -
· Thermistor short
· Defective ac drive board
· Defective main board
· Fusing harness shorted
To reset code :
1. Turn on the main switch.
2. Enter "71" by using the numeral keys.
3. Press and hold the Clear/Stop key until a dot (·) appears in the top left
corner of the Copy Counter and then release it.
4. Press the Clear/Stop key again and then press the Lighter key.
NOTE: "5" will blink in the Copy Counter to show that the SP mode has
been accessed.
5. Enter the desired SP mode number using the numeral keys.
When the E52, E53, or E55 conditions occur, for safety reason
they cannot be cleared by turning off and on the main switch. The
following procedure must be performed to clear these service call
conditions:
2. Turn DPS 101-1 on and off.
3. Turn the main switch off and on.
Jun 16, 2011 | Ricoh FT3713 Copier
My copier uses ricoh 320 toner, it is black en white and its displaying error code e 54. what are the reset codes.
- Possible Causes -
· Thermistor short
To reset code :
been accessed.
When the E52, E53,E54 or E55 conditions occur, for safety reason
conditions:
Ricoh ft 3813 error E54
E54 is a fusing error. You can attempt to reset the code by entering service modes. To do that, you press CLEAR MODES key, then the numbers 1, 0, and 7 and then hold down STOP key. Once in service mode, press 97 then #. That resets the code. Power the machine off then back on to see if it comes back. If it does, then you may need main board or AC driver board.
Mar 14, 2011 | Ricoh FT3713 Copier
The code E54 is showing - what does this code mean?
please press on to (.) signe and write all number
Feb 23, 2011 | Ricoh FT3713 Copier
Ricoh Aficio 1013 error code sc 544
Fusing low temperature error
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
E 54
The E5X code refer to malfunction in the fusing unit.E54 the fusing lamp stay on for longer white the main motor is off.The possible cause is dirty thermistor or thermalfuse,main board or ac drive power supply board is defective.When E% service call conditins occur,for safety reason they can`t be cleared by turning the main switch off/on.You must be performed to clear the service call conditions:
1.After repair the machine turn on the main switch.
2.Enter in the SP mode and press 97.
3.Turn the main switch off amd on.
Sep 23, 2009 | Ricoh FT3713 Copier
Ricoh ft3713 error code e54, where is the fuser and thermistor
You need a tech, or a new machine. The fuser is the heater section nearest the exit of machine - where they are always located. Your error message indicates a blown fuse, or lamp, or thermistor. The code can only be reset in service mode after the problem is fixed.
Mar 08, 2009 | Ricoh FT3713 Copier
Toner overflow
Could be the cleaning blade isn't working on the drum.  Is the paper getting stuck on the fuser unit?
Oct 25, 2008 | Ricoh FT3713 Copier
Richoh FT 3713
E55 Fuser thermistor open
replace thermistor located in fuser
Sep 26, 2008 | Ricoh FT3713 Copier
304 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
