Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
My desktop can't communicate with my printer.
I set my belkin wireless network up. I set my Dell AIO printer to sharing. It is hooked to my desktop. It can't comunicate with my desktop.
    Genius:
  • 1,124 Answers
Disable your antivirus and see what happen.
If works you have to set a rule in your antivirus program to allow the printer be part of your network.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how is it going...
Posted on Oct 16, 2008
Tring to get PC to send signal to hp printer thru belkin N300 router
  • Hook up printer to network.
  • Give the printer a static IP address outside of DHCP scope. (If your network address is 192.168.0.0 typically any address from 192.168.0.1-50 will be. 192.168.0.1 will usually be your router.
  • Install the printer on computer with appropriate driver and install as a network printer, not local.
  • Enter the IP you gave the printer.
  • Done
If your printer doesn't have networking capability let me know and I can explain setting up a printer share.
Jan 10, 2013 | Belkin Basic Wireless Router
Problems with setting up wireless router wrt310n, wireless printer Dell 968W, Dell XPS laptop and Hughes net
Try reseting the wireless router, theres a reset button hold it down for 30 seconds.
Oct 05, 2008 | Computers & Internet
CAN THE DELL AIO 948 PRINTER BE USED FOR SHARING
Yes, If it is connected to a computer on your home network, right click the printer, setup sharing. For example, if you have a laptop on the same home network, Add a network printer to the laptop and print wirelessly without a wireless printer. This may help clarify: http://windows.microsoft.com/en-US/windows7/Install-a-printer-on-a-home-network OR http://windows.microsoft.com/en-US/windows-vista/Install-a-printer-on-a-home-network
Dec 31, 2012 | Dell 948 All-In-One InkJet Printer
I have a Dell desktop aio. Its model is Inspiron 19. Is there a button you have to press to get on WIFI? Thank you
Usually a wireless card does not come with a desktop model, but if you are sure you have a wireless card then follow these steps to determine if it is enabled.
Instructions for XP:
1. Click on Start
2. Click on Settings
3. Click on Network Connections and check to see if there are any connection called "wireless" if so then right click on it and make sure it is enabled. Once enabled double click on the icon and you should be able to view wireless network within range
For Windows 7 or Vista
1. Click on the Start button
2. Click on Control Panel
3. Click on Network and Sharing Centre
4. Click on Set up a new connection or network (from here you will be able to connect to a wireless network if you have a wireless card)
Hope this helps
Thanks
Mar 08, 2011 | Dell XPS One All-in-One TV Desktop with...
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cant connect my hp photosmart c4280 all-in-one printer scanner copier to my dell labtop
CHECK THE FOLLOWING FOLDERS IN THE CONTROL PANEL::
THE NETWORK AND SHARING FOLDER
PROBLEMS AND REPORTS
SECURITY CENTER
WINDOWS DEFENDER
WINDOWS FIREWALL
MOST LIKELY WILL BE SHARING NETWORK AND THE WINDOWS DEFENDER AND FIREWALL
THE FIREWALL STOPS A TWO WAY COMMUNICATION WITH THE DEVICES
RODGANDYSR
PS IF YOU NEED MORE HELP FILL FREE TO CONTACT ME AT CANDYMANGANDY@AOL.COM
THANK YOU
Mar 07, 2009 | HP Photosmart C4280 Aio Printer
Have Belkin Wireless G Router, how do I set up network to allow wireless lap top to access printer?
You have to add or share your printer to the network.
To do that go to the printer folder and select Add a printer (if you dont have any) or if you have one put the cursor over your icon printer and with the right bottom select "Sharing"
Your icon printer will appear with a small hand below and your printer will be visible on the network.
Sep 25, 2008 | Belkin Computers & Internet
Is it possible to connect cat5 cable to phone jack - from the router to the printer
No, Cat5 and phone jacks are purposefully different sizes. They have no compatibility.
If you want to share a printer over a network and it doesn't directly have a cat5 port (most don't) your best option is to set up a basic home network using the wizard, make sure that FILE AND PRINTER SHARING is switched on, and then share the printer as a resource on the machine it's already linked to. Then as long as that machine is turned on (even if it's not doing anything) the printer will be available to other machines on the network, even if those other machines are communicating wirelessly.
Jun 01, 2008 | Belkin Computers & Internet
Belkin N1 Vision - unable to see networked printers
Go on the main PC and Press Start, Control Panel, Printers and Faxes, Right-Click On The Printer You Want To Share, Properties, Sharing...
... If it comes up ( If it doesn't skip to the next part )...
49a8fc3.jpg ... Click on "If you understand the security risks but..."
Click On...
Click Share this Printer, Apply, Ok. Now look on your laptop for network places and you will see the printer on the network.
If you need to contact me email jordylap1@fsmail.net
Jan 21, 2008 | Belkin (F5D5231-4) Router
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
46 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
