Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Doesn't play anymore
The machine will switch on but then gets stuck in the EAX mode and doesn't go any further. It worked perfectly before this episode. I have tried reset and taking the battery out and knocking it above the menu button as another posting suggested. Interestingly if I plug it into the computer it is not recognised either??? Fed up as lots of music on this....
Please help
x
How do i fix my firmware problem
Posted on Oct 21, 2008
Tape loads into play mode then powers off
Probably somekind of damage has occurred inside to the mechanical section. Only looking around will show the cause. When VCRS have a problem playing or any function doesn't do what it is supposed to do a device called a mode switch will go of position and give faulty readings to the electronics, so they power off the video to prevent further damage. The mode switch itself can ware out or become dirty and give false readings on a good mechanism, so that should be checked too. Sometimes you can get away with a spray of Servisol Video 40 on the switch, but if there's any damage cleaning it wont work.
Image below of some mode switches, but they do vary from model to model.
Jun 18, 2012 | Televison & Video
Husqvarna 3610 doesn't pick up lower thread
Hi, Check to see if needle is bent. If the needle is bent it will not work well and soon it will break.
Replace the needle. Also lube the moving parts on your machine. (fine oil) sold in most sewing centers.
Jul 24, 2011 | Husqvarna Viking 1
My ps3 is working perfectly with firmware 3.40 .I started to update firmware 3.41 on thursday 5/8/10 Then i had a problem with my ps3. At first the ps3 downloaded data successfully then it started to...
This is a problem occurring in all the play station 3 consoles....... this is mainly because of some error in board .....as a result it leads to the damage of ur PS3 ....................try to update your system ..........
if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
Stuck on but not playing and no button response
When the EAX screen appears tap it hard on the right side, just above the menu button.  Seriously, it works.  I had to tap several times, finally really hard, but the machine came back.  Many others have posted this tip.
Sep 10, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
My camera gets stuck on the pb mode it does not turn off or switch to camera mod
Had the same problem twice. once solved it by taking out the battery.
This didnt work the next time it happened. but i could access the camera mode. reorded a short movie clip and problem was gone.
Jun 26, 2008 | Canon PowerShot G3 Digital Camera
Fan runs constantly on cool mode
Simple Question: Did you check to see if the fan switch on the
t-stat is in ON or AUTO? If ON the fan runs nonstop. If in auto the fan cycles with the outdoor unit.
next does the fan shut off if you turn the t-stat to off?
A stuck relay should keep the fan running all the time.
Sometimes if the relay is stuck you can whack the side of the Air Handler and the connection will break.
Sometimes instead of a relay there is a stack switch.
It's a little black stack of 3 disks this is a bi-metal switch.
they do get stuck more often than relays.
The fan relay may be on a electronic board. I don't know for sure without seeing your unit.
Good Luck Phil
May 18, 2008 | AmcorAire UCHW-H12AF2 Split System Air...
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
Stuck
thge hard drive gone bad, so the player won't load anymore, replacing the hard drive is pretty easy and will solve the problem
Aug 15, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
I'm stuck in Prggressive Mode on my RDR-VX515
pressing and holding the PAUSE button on the front of the DVD player for 5 seconds. (this is the one that worked for me) Hurray!
pressing the PROGRESSIVE button on the front of the DVD player or P.SCAN button on the remote control to disable the progressive signal.
power off the DVD player and press 369 using the number buttons on the remote control, then power back on the DVD player.
moving the VIDEO OUT switch on the back of the DVD player to the INTERLACED position.
Dec 11, 2006 | Sony RDR-VX515 DVD Recorder/VCR
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
94 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Jazz Boyce
Jazz Boyce
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
