Question about Epson Stylus RX500 All-In-One InkJet Printer
RX500 black ink leaves gaps and holes
The black ink level indicates 80%, and i've done 3 cleanings and tests per Epson's Printer Utility measures. However, the blank ink continues to reproduce broken lines and gaps. What else is there to do, please?
    Problem Solver:
  • 17 Answers
Turn the printer off overnight and try the head cleaning process again. Leaving it unpowered for an extended period softens the ink and makes the cleaning more effective. It may require several cleaning cycles.
Posted on Nov 07, 2008
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I just re inked my Epson styles Photo RX500. All the ink levels read low except Black. I removed all the cartridges and repeated the process.and, all the ink levels read low except black.I get a ERROR...
what is the error message? try to turn off and on your rx500. note for an epson printer it requires all inks inorder for it to function or else it will be on an off line state
Sep 14, 2009 | Epson Stylus Photo RX500 Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Epson Rx500 waste ink collection pads cleaning/renewal......can this be done DIY If so can you advise with detailed method etc Regards Tibbs
The same instructions available all over the internet for the R300 should suffice for the RX500...
In terms of resetting the waste ink counter, the SSC utility will provide the necessary compatibility as well...
Apr 13, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson stylus photo RX500
Apr 05, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson RX500
Are the lines ink? Either you have to keep cleanng the heads until they work correctly or find out where the ink is coming from, if not from dirty heads.(dirty heads means that the ink had drived and you may have to remove them and clean them with rubbing alcohol . What color are they? Replaced any of the ink  cartridge yet?
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=26321&infoType=Overview
Apr 04, 2008 | Epson Stylus RX500 All-In-One InkJet...
INK WARNING
Not very familiar with epson so just a guess:
take out the cartriges turn off the power of the printer, make sure contacts are clean, place cartriges back in and try the align options (works with my hp)
Jan 18, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson rx 500 print problem
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Jan 07, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson RX500 poor test page
Well done. Typically, I advise only ever replacing one cartridge - replacing all is expensive and wasteful
Sep 21, 2007 | Epson Stylus RX500 All-In-One InkJet...
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
138 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
