Question about HP 1040 Plain Paper Inkjet Fax
Machine does not receive faxes
I have a new 1040 Hp and when I installled it ,I can send faxes OK but when I go to receive a fax,it rings 3 times and the sender gets a busy error. I have set the 1040 to answer at 5 rings. I took the fax to another line and it worked properly. What could be wrong with my line. I have an external modum on that line hooked to a hand punch time clock which is polled by the mainframe computer every 15 min but when I hook the fax into the line without the modum, it still does the same thing
    Genius:
  • 2,120 Answers
It the funky line DSL?
Fax machines are designed to be on a dedicated ANALOG phone line. Sorry
Posted on Oct 16, 2008
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
I am having problems receiving a fax.
Check the number of rings your fax machine is set to. Chances are, the answering machine is set up for 4 rings and the fax machine is set up for 6. If this is the case, change the number of rings on your fax machine to 2 or 3 rings to ensure an incoming fax will go directily to the fax machine. If the fax doesn't recognize the call as a fax, it will go through to the answering machine.
Jul 17, 2009 | HP 1040 Plain Paper Inkjet Fax
Fax is not Receiving
Unplug the power cord for 10 seconds.
Do you have DSL or any other kind of digital phone service?
Oct 16, 2008 | HP 1040 Plain Paper Inkjet Fax
HP 1040 "JUNK " FAX MACHINE
can hp 1040 fax transfer printed copies to hp pavillion note pad
eadyj1948@yahoo.com
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Won't receive fax
Reset RING DELAY so that machine picks up on 1st ring, and does not disconnect before fax can be sent to you.
Jan 07, 2008 | HP 1040 Plain Paper Inkjet Fax
HP 1040 Plain Paper Inkjet Fax Logo
147 people viewed this question
Ben Johnson
