Question about LG Electronics LRM-519 Digital Media Recorder
Bk. button Thanks for posting such an easy fix but wheres the black button exactly?
My relatively new, sat idle for two years, LG RHT398H DVD RECORDER has a strange fault the dvd keeps opening and closing at random if a disc is inserted and it wont obey open close commands, or read discs it, the dvd is totally rouge. The rest of the unit is fine. i think it will need re-install of firmware or maybe cleaning any ideas?
Posted on May 10, 2011
Got an error code E000020-0340. Can anybody help with the code description. Probably one of the drums by the related answers in other posts.
Dear
It may unable to adjust the control voltage at Bk inductance initialization.
1. Check if the Drum Unit (Bk) is installed.
2. Check the Drum Unit Relay PCB (Bk)
3. Check the Drum Unit Memory PCB (Bk)
4. Check the harness/connector between the DC Controller PCB and the Drum Unit Relay PCB (Bk)
5. Replace the Drum Unit (Bk).
6. Replace the DC Controller PCB.
Thanks.
Feb 09, 2015 | Office Equipment & Supplies
Number combinations
Shirts by color {bu, gr, re}
Pants by color {BK, BR}
Start choosing shirt color then a possible pans color (bu, BK).
With same shirt color, select the other pants color (bu, BR).
Do the same procedure for the second shirt color gr
(gr, BK), and (gr, BR).
Continue with the 3rd color (re, BK), and (re, BR).
Now gather your results
{(bu, BK),(bu, BR),(gr, BK),(gr, BR),(re, BK), (re, BR)}
For a small number of combinations, one easy way to represent the lot is a probability tree.
Jan 31, 2014 | Computers & Internet
Shirts: red, green, blue. Pants: black, brown. Make a chart showing all possible combinations
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
MP600 printer won't use the 8 BK black ink
Quick and easy way to do this is to use the automatic duplex more as this uses the 8K cartridge instead of the 5K.
Thing to note is that the 8K is the photo black and dyebase whilst the PG5 is a pigment ink.
As a general rule you'll want to use the PG5 because it's cleaner and sharper for text while the 8K is much better for photo quality inks...
... and the reason it's used for duplexing? Simple... it dries quicker! .. So, you don't have to wait as long for the page to be pulled back in and you get less chance of smudging...
Hope that helps...
Mar 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Black wont print
sure. if you re lucky the generic ink hasn t destroyed the ph bk channel yet:
use skyhorse carts (http://www.skyhorse.net.cn ) who built good and reliable carts with a very good ink quality!
To get bk again:
press menu tehn start bk copy then fourtimes arrow up. machines will
be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will initialize the carts, refresh all tubes and ph channels with fesh ink and eliminates the air bubbles (quite a big prob within brother inkjet printers). When finished press 7 -6 -3 to
run a power purge. leave the maintenance mode by pressing 9 then 9. do run a test print.
If you cant see ANY bk the ph is clogged and cant be fixed any more. it needs replacing then.
Apr 05, 2008 | Brother Multi-Function Center MFC-240C...
Unable to print message on Printer LCD
please press menu then start bk-copy (blue-button) then fourtimes arrow-up quickly one after another. machine will be in maintnenace press start bk copy again. What two digit error code does the machine display? Post again here.
(There are more than 20 diffrent errors for unable to print behind ;-))
Mar 14, 2008 | Brother MFC-5840CN All-In-One InkJet...
Black ink is full but does not print.
Did you make sure that the cart was placed well and the plastic hook secures the cart on top?
If you have used Easy Jet carts, you can stop here and give the whole machine a push to the bin!
Easy Jet carts and some other generic ink carts clogg the fine filter in front of the nozzles which cant be cleaned anymore.
The ph as a spare part is more costly than a new mfc 240c at a price discount!
But you can try this at least:
Use a new original brother carts (BK/C/Y/M). place carts and secure them! (this procedure will consume some ink!)
press menu then start bk copy then fourtimes arrow-up button. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph
and will do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy to run a special power purge.
When finished press 9 then 9. After machine is back in normal state run a test print.
If you still cant see any bk the ph cant be fixed anymore.
Jan 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Prints header and footer but nothing in between
Make sure that the carts are FULL, placed well and are secured!
press menu then start bk copy then fourtimes arrow-up-button.
machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will initialize the carts and refresh ink in tubes and the ph. leave the maintenance mode when finished by pressing 9 then 9.
Run a quality test print.
If you still cant see any bk this might be because of generic ink which had clogged the bk channel. this cant be fixed anymore!
Jan 03, 2008 | Brother MFC 420CN All-In-One InkJet...
LG Electronics LRM-519 Digital Media Recorder Logo
98 people viewed this question
Computer Repairing
Computer Repairing
