Question about LG RZ-37LZ55 37 in. HD-Ready LCD Television
Tv stuck on stand by
Stuck on standby has had new pcb fitted but still stuck on standby any ideas?
I have a BUSH LE-32GE11E Flat screen TV. The standby light is very dim red and then the ON light is BRIGHT BLUE, but the TV won't power up. Is this a problem with the PSU PCB?
I'd test all the different voltages produced by the power supply board first. If everything checks OK there, then the main board is faulty. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
May 10, 2017 | Bush Televison & Video
Samsung le19r86bd television which is stuck in standby mode
Sounds as if it won't reboot. Apart from the obvious like turning the power off and waiting, I can't think of much else to do. Have you checked to see if anything is fractionally loose? Is it covered by warranty? If so go back to the manufacturer.
May 06, 2015 | Samsung Televison & Video
Lc195emx stuck in standby mode
Hi D
Sounds like the Switch Mode Power Supply is failing to Power Up.
Often Caused by Bad Electrolytic Capacitors inside the Power Supply Circuitry.
Probably a replaceable PCB Module.
Take it in to your dealer or Electronics technician.
Cheers
Mar 03, 2015 | Televison & Video
My LG 42PQ3000 is making a clicking noise from the large PCB when power is turned on, there is no picture and the stand by light is going on and off
Standby light goin On/Off, means the power supply regulator board is OK. Blinking of the standby light indicates a fault. It might be to the backlight inverter board, or the main board. These blinks of standby light are called blinking codes, from the number of blinks occur at one time switch ON, you can get an idea about the faulty board inside the TV. Count this blinks. If you wish to get more details about these blinking codes, check the site linked here.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 22, 2013 | LG 42PQ3000 42" HDTV Plasma TV
Philips 32PF5531D 32 in LCD tv table top stand
I have a Philips 32PF5520D/10 TV and need the Table top stand that fits it - anyone have any ideas where I can get one ?
Oct 13, 2009 | Philips 32PF5531D 32 in. LCD Television
I have a Pioneer Plasma 434PE and was watching tv when the picture went purple with grain line and then made the screen go blank and now stuck in standby mode flashing red, power comes on but goes back to...
its likely that eith er the y sus or x sus pcb have gone faulty or it could be the main or power supply pcb. if all else fails, check voltages and if they are ok from each point , you need to replace the plasma panel.
Jul 05, 2009 | Televison & Video
MY BUSH TELEVISION MODEL IDLCD27TV006 HAS POWER TO IT AND APPEARS TO BE STUCK ON STAND BY WITH THE STANDBY BUTTON FLASHING WHEN YOU TRY TO SWITCH ON THE TV. ANY IDEAS ANYONE
Just had same problem today. Presumably you've seen the more recent solutions on other web sites regarding replacing the C330 capacitor. It appears to be an over-temperature issue. After trying to press all sorts of buttons, removing plug for a time, leaving off for a time, it just started to work again but I don't know how! The tv stands beside a radiator and this may have been on for a while and caused this problem. Will monitor situation before diving into its innards.
Mar 06, 2009 | Bush 1433GRN2 14" TV
Samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Oct 16, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
LG RZ-37LZ55 37 in. HD-Ready LCD Television Logo
66 people viewed this question
Computer Repairing
Computer Repairing
